Question about Sanyo Split System Air Conditioner
The air is not cold.
I have turned the temperature down to 16 on the remote but the air is still not cold.
  • laura Newman May 13, 2010
    Is the outdoor unit running?
  • 674 Answers
This could possibly be a low refrigerant charge. Is the big copper line or coil icing up? You would need to get someone to check the charge.
Posted on May 14, 2010
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
How do I reduce the temperature to 16
If constantly works, without stoping then its too hot outside and the temperature cant drop to 16.
Jan 25, 2015 | Haier Heating & Cooling
Cannot set correct temperature with remote
the 16 on remote is the set temperature not the room temperature.
Jan 25, 2014 | Heating & Cooling
Not sure how this thing works
Is the air coming out of it cold? It will take a while to cool the whole room down. If it isn't cold then maybe it is short of gas (caused by a gas leak) This may be the reason it was a factory second!! :-S Also, setting it for 16 degrees as opposed to 23 degrees won't make it work any harder. That will be why it runs forever. Air con's usually can't get a room down to 16 degrees!
Jan 16, 2010 | Heating & Cooling
2005 RX8 heater is blowing cold air. Fluids are topped up.
You need to repair the heater core with a soldering gun.
If you do not have heat, or only have heat, IMHO it is most likey the AC/heater control unit. This is the part which has the AC/heat control buttons and knobs.
Easy Diagnosis:
The easiest way to verify this is to turn on the radio, press and hold the power on/off button and press and hold the scan-up button for a second (full second). The word "A/C TEMP" should appear on the left of the display and a number from 0 to 16 on the right. I suspect yours will have the number 0 (or 16 if heating only problem) displayed no matter where you turn the temperature control knob. If this is the case you could turn the temp. knob to full heat and see if it goes to 16 after pushing down or to the right on the knob.
In a working system, the number moves evenly in increments of 1, from 0 to 16 as you turn the temperature knob.
Easy Fix:
I was able to take mine out and solder 3 loose connections to fix it.
The beginning steps are the same as for any radio removal procedure and check for loose connections.
Dec 14, 2009 | 2005 Mazda RX-8
The digital temperature indicator is stuck at 88 and will not change from the remote or the temperature button. Not blowing cold air.
I suggest that you try turning the unit off, unplugging it, and leaving it turned off for a couple of minutes. Sometimes these appliances can be reset by turning them off, waiting, then turning them back on. It's similar to rebooting a computer when it's hung-up.
Aug 12, 2009 | Maytag Heating & Cooling
A/C fan blows enough air but temperature is niether hot or cold
CHECK YOUR PRESSURE SWITCH. IT IS ON YOUR EVAPORATOR.
Aug 04, 2009 | 1999 Cadillac DeVille
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
SANYO REMOTE COTROL
1.check remote its working properly or not.
2.check temperature control switch.
3.put the temperature put below 16 n on the unit
4.if not working change the remote
Mar 27, 2008 | Heating & Cooling
Sanyo  Split System Air Conditioner Logo
134 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
