Question about HP LaserJet 3200 All-In-One Printer
How to get HP 3200 All-in-One to scan
Installed software for printer from cd that came with it. I still don't have 'scan' capability. The SCAN button doesn't light up and when I press it I get a message that I need to check the documentation.
    Genius:
  • HP Master
  • 1,354 Answers
Frist of all chack HP cd is supporting your Windows or what you do just go to HP site and download drivers acording to your oprating system
Posted on May 13, 2010
My HPc310 continues to tell me to "start scan from computer. refer to documentation" how to I stop this and scan TO the computer?
The Scan button behavior hasn't been set up on the computer. If you haven't installed the Full feature software, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4231205& . Select your OS and then Next. Select the second option under Drivers.
If you installed the Windows OS basic driver, uninstall that driver and disconnect the data cable.
Once this software is installed, double-click on the HP Solutions Center. Try to scan once to find the best settings. Then in the Settings section of the software, you can set the Button destinations. Set the Scan-to button.
Now if the software is monitoring the printer, pressing the scan button will launch the HP Solution Center scan.
I hope this helps.
Apr 03, 2013 | HP PhotoSmart Office Equipment & Supplies
Can not scan
When this happen it is usually the USB cable. When this happen it is usually a problem with the USB cable. If
communication on USB cable is bad, as a result you can print but not
scan.Having also messed up a bit with the drivers ("HP digital
monitoring icon anymore"), you may also need to reinstall the driver.
My suggestion on how to proceed is the following.
Buy a better usb cable, the shilded ones cost a couple of dollars more but guarantee better communication.
Unplug printer from usb.
Unplug computer and printer from power for two minutes.
Plug back computer and printer to power, DO NOT plug in USB cable yet, leave printer NOT connected to pc.
Reinstall
drivers and software, keep printer disconnected until connection is
explicitely required by printer software installation process, or after
installing.
Connect printer when required.
Check that there is no
electric device (power adapters, extension etc.) very near to printer
USB cable, they can cause electromagnetic disturbance.
Try scanning. If it does not work at thhis point is either a problem with windows (new windows install required) or a faulty scanner.
Jul 29, 2008 | HP Officejet 5610 All-In-One InkJet...
When I try to scan on my HP Officejet 6500 Wireless it says "No Scan Options" on the little screen what should I do?
Do you have the full software installed on the computer, if available? You can get the software here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795406& for supported OS versions. Select your OS and click Next. (The basic drivers will not support launching scans from the all-in-one.) I don't believe the buttons work with the Mac OS, unfortunately.
Can you launch a scan from the computer? Next check that the digital imaging monitor is running. The digital imaging monitor is only in the full featured software and listens for the button press. If yes, then you haven't set the destinations for the scan buttons in the software. Launch the HP Solution Center and go to Settings. Then set the Scan Settings > Button Settings > Front Panel Scan Buttons for Scan to E-mail and Scan to File.
I hope this helps.
Sep 08, 2011 | HP Officejet 6500 Wireless All-in-One...
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
How do I scan a document from my HP officejet J4580 all-in-one printer to my computer?
Make sure the full feature software package of the printer is installed.
Press the Scan button on then press scan button on the printer to scan, or you can also scan via HP software.
Aug 20, 2010 | HP OfficeJet J4580 All-In-One Laser...
Attempt to scan, screen states
This error occurs because the HP scanner can not communicate with your computer and thus won't scan. In most cases this is simply because you don't have all of the necessary drivers installed.
  1. Insert the software CD into your CD ROM drive. The software installer should automatically start
  2. Install the software and restart your computer when prompted
  3. Try to Scan using the Scan To or Start Scan buttons on your printer
Jan 13, 2010 | Computers & Internet
I need to know how to scan
make sure the software cd that came with the machine is installed, then turn on the machine and make sure its connected to your computer and your computer is turned on and you are on the desktop, press on the scan button on the machine, scanning should come up on your computer if it doesn't come up then press start, then run, type: mspaint and click OK
in paint, press File and then select from scanner or camera, scan and save your scan to your computer.
Oct 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7580
scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
  1. Open the HP Director/Solution Center software.
  2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
  3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
  4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
    Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
Causes:
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
regards,
coffeebeans
Mar 15, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HOW TO SCAN ON HP PSC 1315
i have a Vista system and an old hp 1315. the CD driver that came with it includes some very useful software that cannot be installed in my laptop. according to the hp website, that's because Vista comes with a compatible software for my hardware. checking Windows Help & Support gave me this solution:
Open to Windows Photo Gallery, click File then click Import from Camera or Scanner.
i did exactly that and it worked!
i hope this was of some help.
Jan 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 3200 All-In-One Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
