Question about GE Spacemaker JVM1640SJ Microwave Oven
Will not turn on - says F-3
  • GE Master
  • 9,047 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Please contact us with your full model number for free tips, advice, and an estimate.
Posted on May 16, 2010
Microwave turns off after 3 seconds
Your description indicates one or too bad door switches, since there are a few of them a digital meter is required to test them along with the dis-assembly of the microwave oven, due to the high voltage danger I recommend a technician for the job.
Jul 23, 2012 | Microwave Ovens
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
Just bought new Samsung SMH9151 OTR Microwave. Installed it and it turns on for 3 seconds and turns off. I took it back down and just plugged it in the wall plug (while sitting on the counter) and same...
I don't mean to be coy, but if you bought it from a local company (Best Buy, Lowes, Home Depot), take it back (within the 30 day window) for a refund. I bought three microwaves (all poor quality) and returned them all!
I may be returning this Samsung if your review turns out to be true for my microwave.
Jun 03, 2010 | Samsung SMH9151 Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
It stoped
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 01, 2008 | Panasonic NN-S542 Microwave Oven
NNS449WF MICROWAVE OVEN PANASONIC
Usually you press Start 3 times to turn the child lock on, and press Stop/Reset 3 times to turn it off.
If that doesn't work, you can probably unplug it for a couple of minutes, then reset the clock.
Oct 04, 2008 | Panasonic Microwave Ovens
PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 24, 2008 | Microwave Ovens
Sanyo EM-G2585W 800 Watts Microwave Oven
It's possible that the unit is overheating, and shutting itself down to make sure that it doesn't melt or burn. Do you have it against a wall, or in a cabinet where the unit cannot vent? Is there a fan? Is it working? --j.
Jun 19, 2007 | Sanyo EM-G2585W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
155 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
