Question about Maytag Washing Machines
My epic mfw 9600sqo is not spinning and draining properly. The error lights have been coming on lately. If I unplug the washer it usually resets.. but that is a hassel. The electronics seem to get stuck in the rinse cycle.. the door locks and none of the buttons will engage on the new command. Maytag was no help... I needed the serial number which was locked inside of the front loading door... After unplugging for a day it seemed the electronics and the buttons started working again.
SOURCE: control lock light
Try holding in the "End of Cycle"tone button
Posted on Dec 16, 2006
the dr
  • 447 Answers
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Posted on Jan 01, 2008
  • 13 Answers
SOURCE: My Whirlpool Duet Front Load Washer stopped mid
Your filter could be clogged. You might want to try cleaning it if you haven't done it before, Here's how.
1.Turn power off at breaker or unplug the washer.
2.Unscrew the 3 star head bolts on the bottom panel.
3.Right in front of you you'll see a white plastic with 2 hoses going into it and a black box attached. It has a circular knob. That's where the filter is located.
4. Unscrew the 1 silver screw attaching the filter housing to the washer... this will make it easier to access the white hose clamp. Slide the housing towards you to free it from the washer frame.
5. Grab a bucket to catch the water that's in the hose and place a towel under the washer too, this will keep any stray water from going all over.
6.You can use a pair of Chanel lock pliers to squeeze the hose clamp on the smaller white hose while you pull it free from the housing, aim that hose into the bucket and shake it a bit to get any particles out until it stops draining.
7. Now you can unscrew the white circular filter knob to the left, be prepared for some water to come out, keep the bucket and towel handy for this.
8. Pull the filter all the way out and more than likely you'll be surprised by how much **** is in there lol, I had a small screw driver, a nail, coins and many other misc. debris.
9. Shake the filter housing a little while its over the plastic bucket to help drain excess water and crud out of the hose and housing.
10. Clean the filter and make sure all the holes are clear.
11. Reinstall the opposite way you took it apart but keep the lower panel off to make sure nothing is leaking after you do step 12.
12.Turn the power back on and press the cancel button twice and make sure the washer is set to spin and drain cycle and run and watch it off and on until its done.
13. Go ahead and put the lower panel back on.
Hope that helps :D
Posted on Dec 28, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
  • 58 Answers
SOURCE: I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Posted on Mar 09, 2010
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Maytag epic Z Washer shuts down at spin cycle
F21 usually indicates a pump problem however when that is not the problem then the place to look is the board itself as there is a mis communication between it and pump cycle? If the pump cannot operate it will not allow it to go into the spin.
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
I just moved and my washer through the error code "sud" when it started to spin it wont drain either.
You have either overloaded the machine, or you have used too much soap. unplug washer for about 10 minutes. set to rinse and spin, should work fine. If you cant get it to work tried putting some veggetable oil to kill the suds.
Nov 30, 2010 | Maytag EPIC MFW9700S Front Load Washer
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My MFW 9700S will not exit the final spin cycle. I'm on 220 current stepped down to 110. Is that a problem?
hellow: i think not related to current the biggest final spine period i see is 8:9 minute if you have more i think it come from the timer may be it has to change
Jun 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
