Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Image stretched widthways
Since my computer was repaired the picture on the monitor screen appears stretched widthways giving a strange appearance to photos.
How do I restore the original size?
  • 748 Answers
Hi
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
Posted on May 13, 2010
Screen image is stretched or smeared
I had that problem, after awhile of using mine, the words would appear to be streaking. I bought a new monitor.
Feb 19, 2014 | Gateway FPD1975W 19" LCD Monitor
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
The desktop and applications are stretched
right mouse click on the desktop and select properties. Then go to the settings tabe and change the resolution. A picture of the screen shape on that window should give you an indication of whether or not you have chosen a compatible resolution
Jan 06, 2010 | Acer P221W LCD Monitor
Screen appears squeezed from left and right sides
Sounds like the video card settings are over-riding the monitor settings. Go to display settings in control panel, and try the one that says "recommended". The other thing I have found out is sometimes the monitors start doing strange things before giving out completely.
Nov 30, 2017 | Dell E771a 17" CRT Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Acer X193W Monitor / screen image
Check your video card drivers are installed correctly.
If unsure, the reinstall them again, it won't hurt the system and there are probably new drivers out for it anyway.
Apr 12, 2008 | Acer X193W LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
434 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
