Honeywell central AC/heat Electronic fan timer st9103a 1036. Honeywell is no help. They want me to buy a new board for 150$. I believe its the IC on the board that's bad. I have not been able to find a schematic of this board. The IC is labeled: L 9948 814 (large dot) Y I've tried a few on line part suppliers and they cant identify it. It has four pins. Home was hit by lightning and it fried 3 items on 3 different house circuits One was the AC. The above board is telling the fan and the heater to turn of, even though the thermostat is off. I've troubleshooted and believe its this IC and want to replace it. Can anyone help me finding the original manufacturer?
  • 30 Answers
SOURCE: Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Posted on Feb 04, 2008
SOURCE: Honeywell electronic thermostat malfunction for oil heat zone
Try changing the batteries.
Posted on Mar 04, 2008
koolbreezes
  • 540 Answers
SOURCE: got a honeywell t8400c thermostat
R--- rc or rh y--yellow g---green w--white red is power yellow is cool g--fan white is heat
Posted on Sep 03, 2008
tborn6
  • 700 Answers
SOURCE: Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Posted on Jan 25, 2009
tborn6
  • 700 Answers
SOURCE: Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
TROUBLE REPLACING OEM TIMER - UNIVERSAL ELECTRONIC FAN TIMER
Hi, you should be real close with the universal timer and the factory OEM. On the new control board, if you have 24 volts to the board, you should have 24 volts from R to ground or to Common. I know that on most all control boards the voltage in is 120volts as you will have terminals for L-1 and L-2 to run the high voltage controls from the board and all of the thermostat control terminals in a row, R,G,Y, W, C, and so on are 24 volts. 120 volts is stepped down to 24volts control and you say you have nothing out. Make sure you have 120volts in. You are calling this a timer board, is this a heat-pump defrost board with the 3 settings and pin to defrost the unit at 30,60,and 90 minute times? This is what it sounds like. If all was terminated per diagram, you would have the 24 volts required to fire this unit. These defrost timer boards require high voltage to them as well. Even though the board is a new board and you know for a fact that it is wired properly, it may be a defective board. I have seen this many times in my years as a tech. I have shorted new boards out by static electricity and by mis- wiring one. You can kill power and look at the back side of the board to see if this has happened. Sometimes you will find that they missed a solder point on the back side not completing a circuit through the board. To give you more ideas, I would need to see the diagram, or if you could send me the model, serial, and name of your unit. The board number would help also. Check out what I have said and get back to me on this. I will wait to hear.
Shastalaker7
Jun 06, 2010 | Heating & Cooling
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Nov 18, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Jan 25, 2009 | Honeywell Electronic Programmable...
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
