Question about Canon imageCLASS MF6590 Copier
Whenever copies are made, or a fax comes in, the machine squeaks very loudly. How can I fix this?
It was helpful for me to remove the toner cartridge and spray a blast of air onto any exposed rollers (inside the printer, behind where the cartridge rests) in case excess paper dust had collected and was responsible for the squeaking. However, don't go spray crazy - spray in short, quick bursts. If the equipment becomes coated with a frost of ice you're spraying too much and that could cause damage.
Posted on May 27, 2010
  • 1,219 Answers
Can you say from where the sound comes? If from left side check the drum unit and fixing unit. If from back check if all plates or main motor, or fan are ok.
If from paper tray check for any breakage, paper leftovers,...
Hope that helped
Posted on May 14, 2010
  • Jan Koellen Nov 08, 2011
    There are some built in auto-cleaning settings under additional functions #8, adjusting/cleaning. You put plain paper in the multi-function tray to run the transfer roller cleaning. It goes very slow so you won't be able to use the machine for 2-5 minutes. It might depend on how dirty it is too. For the Feeder cleaning put 5 sheets of letter paper in the ADF & run that. It might not get rid of the noise totally but may help if it is just caused by paper & toner dust. Done regularly it might prevent the problem. FYI, some copier techs have vacuums that do a really good job of cleaning out a dirty copier/printer/fax. Part of the service should be cleaning all the dust out whenever they work on your equipment.
The dryer squeaks loudly
The dryer has been over loaded too often. Try to determine if squeak is from the front or back. The felt pad dirty. If it is from the bottom, then the tension roller is binding and needs lubrication.
Nov 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
My printer is squeaking very loudly whenever it
Take it apart, and clean and lube the components.
Oct 14, 2009 | Lexmark C532dn Laser Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Washer make a loud squeak when the spinning stops
This is a very com. prob. with this unit. its is expensive to fix and will come right back when humid out best thing to do is just put up with it.
Apr 06, 2008 | Washing Machines
Paper failure
If you can see the black rubber feed rollers, clean with isopropyl alcohol
Oct 24, 2007 | HP 920 Plain Paper Fax
Copy problem
ONE OF THE DOCUMENT SENSOR IS FAULTY OR DIRTY AND IS NOT RESPONDING CLEAN/REPLACE , PROBLEM WILL BE RESOLVED
Aug 22, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
Sending and Copying Problem
THE SCANNER NEEDS CLEANING HAPPY FAXING OMNIPRESENT
Mar 27, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Canon imageCLASS MF6590 Copier Logo
180 people viewed this question
old marine
old marine
