Question about Fuji FinePix V10 Digital Camera
When I turn the power on....it reads "FOCUS ERROR"......then a red square pops up and the camera powers off.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 13, 2010
Red focus squares show on pictures
Disable the "AF Point Display" in the menu.
If you need a manual, you may download a copy at Owners Manual User Guide for Canon EOS 60D Digital Camera EOS60D pdf
Sep 25, 2016 | Canon EOS 60D Digital Camera
Focusing problem
Perhaps your only option is to send it in for repairs .
Sep 07, 2015 | Cameras
My canon rebel xsi is not letting me take a picture on auto focus
It is possible you are trying to focus on somethind that is either completly white or completely black. It has trouble focusing in the dark as well. make sure your auto focus point (The red dots in your view finder is in the centre. you can move the red dot with the button on top of your camera that looks like 4 squares. simply look through your viewfinder push the shutter button down half way and the red dot should flash. if it isn't in the centre then move it with the button on top (4 squares) and try again until you get it in the centre.
Aug 16, 2010 | Canon EOS Rebel XSi Digital Camera
Hello! I have a SANYO VPC E1090 digital camera. When I turn iton the LCD screen has a red bar across the top and says "Lens Error 0x0311" and then powers down. Do you have any suggestions other than...
The lens error refers to a 'binding' in the mechanism for focusing.
The camera will not operate if this error exists. So, it's important for the owner to try to seek repair service for the camera.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Aug 07, 2010 | Sanyo Cameras
Lens unable to auto focus
try cleaning the lens.
Also set the focus range in the camera to average both vertically and horizontally. That is when you press the shutter button thos red squares in the look through a;; ;light up rather than just the centre square.
I suspect it is getting feedback from something on the lens that it reads and tries to focus on that is closer than the object you want to photograph. Make sure there is no mold growth inside lens as that will do it too
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Turn on camera,lens pops out,goes in/out focus reads lens error
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 15, 2009 | Nikon COOLPIX L18 Digital Camera
Hi I bought this camera Fujifilm finepix s10000 fd in order to photograph sharp and clear close up pictures the best way I can. When I press the Menu/ok button = nothing happens. It simply does not...
if your wanting to do macro photography (close up) on the dial on the back, click the left button on the circle and a little flower should pop up on the screen saying "Macro, close up shots" this is for pictures that are closer up then regular and U want them in focus. it takes a few times to get it focused a few times but when it is focused properly, the square in the middle of the screen should be red. if you want really close up, click the button another time and the flower should come up again and it should say "macro close up shots up to 2cm (0.8in). once again once its focused properly the square will be red. you will have to practice because it takes time to learn where its proper focusing points are but i'm sure you will get the hang of it.
Aug 04, 2009 | Fuji FinePix S1000FD Digital Camera
SD550 camera not focusing correctly. Green focus square sometimes shows up, sometimes not, either way, it's not clear even on the digital screen prior to taking the shot. Camera does make a slight click...
to make the green square show up just press the shutter button until half (this is called the half press) when the green square shows up then it means that the camera has focused already, if not repeat the process til green square comes out you can press the shutter button fully to take picture when you see the green square...
Jul 06, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Flashing red square area in viewfinder.
No, I don't think so, there could be differences between the Auto and the P setting. But the red flashing is where your camera is currently focusing on. It's possible that the black was indicating the focus box, but it was not latched on to something with complete focus, which then is indicated by the red flashing. Check this link to read up further on this. I may not have pinpointed it exactly, because I have a D70s, but that's what I found so far. You'll maybe have to reset everything and see if it's still there, otherwise, it's a setting. =)
Nov 20, 2007 | Nikon D40x Digital Camera
Powershot S1 Digital Camera: Flash won't fire
Make sure the camera is not in Document mode . Document takes a picture with added contrast so text stands out. Make sure the camera is not set to Infinity focus . When you select Infinity Focus, the camera automatically turns off the flash and auto focus so you get sharp, clear pictures. Make sure the camera is set to Fill, Auto, or Red Eye flash. See your camera manual for details about setting the flash.
Dec 31, 2005 | Canon PowerShot S1 IS Digital Camera
Fuji FinePix V10 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
