Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Question on a Konica Bizhub 600. Works well after a PM is done, but is starving for toner after 15,000 copies. Is there a way to increase toner output?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Make sure that during the PM the LD1 and LD2 adjustments are done. If they are set too light or too dark it will cause over toning or under toning. Also check the gears on the back of the developer unit, there is one small gear that can wear down. This gear drives the augers that add the toner to the developer mag roller.
Posted on May 13, 2010
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Oct 28, 2015 | Konica Minolta bizhub Office Equipment &...
Has anyone had scuming on back side of sheet only. if so what was the fix.
Sir/Mam,
Yes you mite need to have the upper and lower fuser rollers replaced. When was the last time a Preventive Maintenance (PM) Kit 250K was done. every 250K copies the machine needs a PM and the developer needs replacement. The drum is replaced every 500k. Is there a tiny wrench being displayed in the upper right of the op screen? If so PM required.
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
I have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please tell me what is the...
When is the last time a full PM was done. with the counter properly cleared and require procedures where done after the developer and drum are replaced, did you clear the counters for the new drum?? Replacing the heater (FUSER/FIXER is not the problem) A good cleaning in and around the Photo drum and developer section with the developer replaced and counters properly check and so get a qualified Konica Minolta Tech out to look at the machine. My recommendation
Oct 29, 2012 | Konica Minolta Bizhub 600 750 Image...
What's your problem?i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy p
When the last time the machine was cleaned in the drum area along with the associated sensors, when was the last time drum and developer replaced, every 250,000 copies drum developer should be replaced.
Oct 29, 2012 | Genuine Konica Minolta Konica Minolta...
What's your i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please te
Mite be that the copier need s a cleaning inside because it can not complete a copy cycle such as monitor the density of the toner on the drum have a tech do a cleaning when was the last time a 250,000 copy Preventive Maintenance Kit was done on it! Very 250,000 PM is done every 500K new drum. Does your machine a small wrench on the operator screen upper right hand of the purple/white screen
Oct 29, 2012 | Konica Minolta Developer 02xk Dv710 for...
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
TCR adjustment
This can only be executed in service mode and is the machine saying it has been starved of toner, i would advise that a technician carries this out as usually there is a problem that has caused it.
Jun 12, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
399 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
