Question about Baxter OV300G Stainless Steel 27817 Watts Toaster Oven with Convection Cooking
Oven gives air flow fault message . I did check all the safties ,motors everythings looks fine any suggestions
Check your combustion switch to see if it has a screw to adjust the amount of vacuum needed to prove the air flow. Adjust it down. Bypass the switch to see if the problem continues, if it does it is in the PCB or the ignitor control. If the problem goes away then replace the combustion relay switch (proves air flow).
Posted on Sep 08, 2010
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
I am looking for a replacement knob for Euro-Pro TO240L. It is the knob on the bottom the sets the time control.
If you no longer have the papers with the oven (since I would have suggested to call the company), here is a website address that will give you a list of sites that carry oven parts. Hopefully one of them will have the knob.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Use copy and paste to put into address bar.
Mar 21, 2011 | Euro-Pro TO240 Toaster Oven with...
Manual for euro pro x rotisserie air convection oven = = please that is all I need = = I have picture Euro-Pro Digital Rotisserie Toaster Oven\r\n 3.5 stars 10 reviews Prices, promotions, styles and...
If you are unable to contact Euro-Pro, then a good website to check on is manualsonline.com. If that fails try a search on the internet. Sorry I can't be of more help, but you didn't give a model #.
Mar 18, 2011 | Euro-Pro Toaster Ovens
Have T4800 Convection Oven. Need fan, motor and thermostat cannot locate parts.
If Farberware can't help then copy and paste this address. It will give you a list of sites that carry oven parts. Maybe one of them can help.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
Have T4800 Convection Oven, need fan, motor and thermostat. Cannot locate any parts.
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
farberware-electric@saltonusa.com 1-800-233-9054
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Whirlpool fan assisted oven - fan motor coil burning out
    The PCB board is definitely at fault here. One of the dc voltage lines is transferring too much current. The regulator and resistors are probably compromised. The better option is to replace the board than to try and fault find the components.
    please rate my help++++Thanks for using FIXYA
    Jun 23, 2010 | Toaster Ovens
    Hot plate not working
    Check the non working plate element for continuity - if open replace it. Otherwise the switch is bogus.
    Sep 04, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
    Farberware 460 turbo oven
    R
    I have the same oven plus another one. Does this model have a "ding" when the timer is finished. My other one does. I bought them both used. Love em for their size. I use them out in the garage during the summer. Keeps the heat out there
    Thank you
    Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
    "Err"or message with beeping
    Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
    Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
    Baxter OV300G Stainless Steel 27817 Watts Toaster Oven with Convection Cooking Logo
    117 people viewed this question
    Top Baxter Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Baxter Toaster Oven Expert? Answer questions, earn points and help others
