Cannon IR C5800
Does anyone know what this error means and how to fix it on the Cannon ImageRunner C5800: Canon
Imagerunner
C5800
Error: E-000070-0102
Thanks in advance
  • 38 Answers
According to my info this is an error detecting the home position of the image transfer belt. It may be a problem with the sensor or one of the boards, but there is also mention that if there is paper in the mbypass tray in low humidity environments that due to static electrcity electrical noise may occur and result in the incorrect detection of the ITB home position.
I would say first step is if you have paper in the bypass tray, remove it and restart the machine and see what happens. If your problem still perists i would recommend that you have a Canon Techncian come out to have a look
Posted on May 10, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Ir3300 e805 error sollution
if cannon ir 2200-3300 shows error E00805-0000 THEN fixing fan is not workig fan is jam oiling d fan then fan is not work change fixing fan.
Jul 15, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
The canon ir 3225 gives me error e 000280 - 000 code please assist
i have the cannon ir 3225 and i use id management & pasword but i forgot the management id and pasword...how to riset pasword and solve the problem
Sep 06, 2011 | Canon imageRUNNER 3225 Black and White...
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
that is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
May 18, 2011 | Canon ImageRUNNER 330s Copier
I have a Canon NP 4080 with an error code E540. When I looked it up it read: lateral movement motor lock. It's an old machine; would like to fix it myself. Any ideas
Hello
According to Cannon
the error E540 is the Stack shift sensor error which may be damage or gone bad, it is recommended that you may consult Cannon Technician for repair.
Hope this helps, good luck
Jan 06, 2011 | Canon imageRUNNER iR C4080 Color Copier
Does anyone know how to fix error E000602-0402 on Canon ImageRunner C5800?
You need to change the HDD, upload a new system, language, RUI,... Call service because you need the service tool software
Pls. rate
May 04, 2010 | Canon imageRUNNER C5800 Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Error E070 0002
I don't know which model you're having problems with but if it's an IR-C2058 the error has to do with the Transfer Belt. The 0002 says the transfer belt sensor ( S51 ) continues to detect the home postion for transfer belt. I don't know what kind of work you've done to the copier, if any, but the error will have to be cleared up first. Let me know what model and I can help alot more. Good luck.
Feb 11, 2008 | Canon imageRUNNER 400S Copier
456 people viewed this question
jasbo
jasbo
