Question about PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner
Scan picture but only half picture shows up. - PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
I have the 52 inch home theater and the picture shifted and is shows the picture but half way because the top of the screen shows black
hi,
you could try resoldering the vertical scan ic and changing electrolytic capacitors near it, as they have probably dried out due to the heat over the years. cant give you the position numbers as i have no manual but the ic should be on a heatsink on the deflection board,usually vertically mounted and with 5-9 leg.
ok
Dec 23, 2010 | RCA P52926 52" Rear Projection Television
Just purchased a canon pixma mp 250 printer. pr...
The printer dosen't get ready after ON, it show half (0) on display screen.
May 20, 2010 | Computers & Internet
Half screen showing picture other half showing color lines
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Apr 19, 2010 | Toshiba REGZA 52RV530U LCD TV
When copying it randomly makes a loud noise and
see scan connector care fully and give me a good vote
Apr 13, 2010 | Sharp AR-407 Copier
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
SCAN
ok" what you have to do is a pre-scan, in the pre-scan menu click on the your picture hold button down and drag a box will apear around the picture telling the computer what part of the picture you want scaned by draging that box.
Then do a regular scan
Dec 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner Logo
151 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
