Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Cant get any wireless fron a befw11s4 router . The router was plugged in into a 220 volt by accident. the plug gotm burnt out. i got it fixed. the router is working but i cannot get any access wirelessly
Benimur
  • 6966 Answers
SOURCE: i lost my lynksis befw11s4 router star up disc what can i do
There are 5 versions of this model. The drivers for your LinkSys BEFW11S4 Router are available here. You have to select which version you have and can be found at the sticker underneath the router.
Good luck and kind regards.
Posted on Oct 25, 2007
  • 173 Answers
SOURCE: cant go online wireless (working before)
Hi jamesone..
This router will not support vista laptops..and the warranty period for this router is only a single year..better you can go for advanced g or gs routers .. model no's like..wrt54g or wrt54gs..with a warranty perion of 3 years..
HI baby..
this is for u..
It seems that you are not connected to the wireless connection ..i think the operating system in your laptop would be xp..to fix this problem
right click > wireless n/w connection > click view wirelss network connection > click change the order of the preffered network connections > select your wireless network name > from preffered wireless network and remove it..and then right click wireless network connection icon again and try connect to the network.. you will get connect.. and will get an ipaddress..
Posted on Dec 05, 2007
  • 556 Answers
SOURCE: drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Posted on Dec 09, 2007
2Gigs
  • 141 Answers
SOURCE: Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Posted on Mar 14, 2008
  • 104 Answers
SOURCE: securing my wireless linksys BEFW11S4 ver. 4
I’ll be pleased to help if I can. To answer your last question first, this router is already set up for wireless networking, so nothing further needs to be done with regard to that.
However, to prevent others using your connection, it's necessary to set up wireless security. There are four main steps, which are the same for most routers:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
3) Enable WPA encryption
Here are the details:
1) Login to your router, using a wired connection.
First, you will need an Ethernet cable to connect one of your computers to the router. This cable just plugs into a spare port on the back of your router, while the other end plugs into the Ethernet port on your computer (looks like this picture).
When you are connected, open a web browser on your computer. Type the router’s IP address into the address bar, which is http://192.168.1.1 for this model. (Note, there is no ‘www’)
You should then see a popup box, prompting you for a username and password. If these have not been changed, leave username blank and enter password: admin
If you log in successfully, you should then see the Linksys router configuration screen.
2) Change the router login password.
To set a new password, go to Administration > Management. Set and confirm a new Router Password. On this screen, I would also recommend that ‘Remote Upgrade’ and ‘Remote Administration’ are disabled. Click ‘Save Settings’ when finished.
(Tip: write the password on a label and stick it on the router, or keep it somewhere safe. )
3) Change the SSID (router name):
Go to Wireless > Basic Wireless Settings. Change the ‘Wireless Network Name (SSID)’ from the default, to anything you like, that you can remember. It is case sensitive, and you can use up to 32 letters –but do not use something that could identify you, or your location.
At this stage I’d recommend that SSID broadcast remains enabled.
4) Enable WPA encryption
Go to Wireless > Wireless Security. Enable Wireless Security. Under ‘Security Mode’ you have a number of options for encryption, but I would pick WPA-Pre-Shared Key, which is very secure and good for most equipment.
Under ‘WPA Shared Key’ you need to enter a network key. This is a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers
( eg: 456the51stSTATeOFtheUSA1599 ). It is case sensitive. The stronger the network key the better, if you are very concerned about security.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called the WPA shared key, PSK, WPA-PSK, pre-shared key, security key, passphrase, or authentication key). Click ‘Save settings’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your network with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work, or if you need help with any of it.
Posted on Jan 17, 2009
I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
Jun 23, 2015 | Oliso TG-1000 Iron
Will American power tool batteries work after being plugged into a 220 charger
Yep. they will as long as the 220 volt charger was connected to 220. If a 220 volt charger is plugged into 110 volts it may not charge the battery but no damage to the battery will happen.
Dec 04, 2014 | Drills
I have fa linksys router model BEFW11S4. I NEED THE PIN NUMBER, WHERE CAN I FIND IT? I DON'T HAVE THE MANUAL OR CD OR BOX. PLEASE HELP
Should be on the White sticker on the bottom. If you need to login to the router to change settings You need to access the router setup page by typing 192.168.1.1 on the address bar of a computer that is working with the router , then it will be asking you for a username and password , just leave the username blank and password is admin.
If you need to connect wirelessly to the router but there is a password you don't now you need to hard reset it: unplug it and hold the button on the back that says reset for 30 secs and plug it back in then connect. you must use a cord connection first to login to turn on wireless.
Jun 14, 2011 | Linksys BEFW11S4 802.11b Wireless...
Is there softwear for this linksys BEFW11S4 wireless B. we cant get the wireless to work for my xbox 360
No, no software but there is a User Manual.
You will need to locate what Version you have (there are 4.) via the drop-down selection before you can download your User Guide here
Linksys Support
Feb 10, 2011 | Linksys BEFW11S4 Wireless-B Broadband...
I am trying to figure out if I can plug my new router into this 220Volt plug or do I have to plug it up to the transformer I was given since I live in south korea
Please see on the adapter of the router if the range of voltage is from 110 to 220. If it is then it is called auto-volt. The adapter can adapt whether 220 or 110. You can directly connect it to any socket.
If it is not auto-volt then you must use a step down transformer to use it.
Thanks.
regards,
longgee
Dec 27, 2010 | Belkin Wireless Surf Router (F7D2301)
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
My Linksys BEFW11S4 Wireless-B Broadband Router? i cant connect in my internet and my PSP how can i do to connect it?
Set up an open wireless network or with WPA encryption. The PSP supports WEP/WPA but not WPA2 or Wireless G, it's a B device.
Also use a short passphrase and DHCP to lease IP Addresses.
Nov 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Cant go online wireless (working before)
Hi jamesone..
HI baby..
this is for u..
Nov 29, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Configuring the BEFW11S4 for the first time
To configure your router to share your Internet service, please follow the steps below: 1. Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. 2. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. 3. If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online (Step 1), visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 4. Once one computer is able to access the Internet through the router, the router will then be configured. Other machines can now connect to the router without re-configuring it a second time. 5. If you are still having difficulties setting up your router, please contact Linksys Technical Support so that we may further assist you.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
24 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
