Question about Zenith DVP615 Portable DVD Player
Dvp615 says check disk but then can't read it. Help!!!
Same issue as the other ones here. reads cd's but not dvd's. can you help? Please reply to fja333@hotmail.com.
Thanks!!!
    Problem Solver:
  • 22 Answers
Maybe your player is not capable for reading dvd disc or your player is smuggle... return the product to the store if it is under warranty...
Posted on May 08, 2008
I have a Zennith portable CD-R/RW cd's play just
The problem it´s the motor disc spindle loses velocity and that´s why they can´t read the dvd
May 18, 2010 | Zenith DVP615 Portable DVD Player
MY DVD-RE IS NOT READING ANY CD OR DVD..WHEN I M INSERTING ANY DISK IT KEEPS ON READING IT
Try using a Iris eye cleaning disk. Mosxt times when constant reading occurs or it says no disk it is the iris inside that has become occluded with dirt. Checkl that there are no finger marks on the disk and it is clean too
Once you have run the cleaning disk use a non scratched clean disk to check its load and read ability before trying in the disks that you had trouble with.
If they still give trouble then the problem will be with those disks and not the laser in the unit.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung SH-S202J 20x DVD?±RW DL IDE Drive ...
Wont read disks
HI...
Wet a cotton swab with eyeglass cleaner and GENTLY buff the laser lens
( The little clear unit on the laser pickup/reader. Then dry off with another swab. If you can get a can of "Dust-off" compressed CO2, try a couple sprays of that towards the Disc reader.
If this helps, rate my help please.
Thanks
Sep 30, 2009 | Zenith DVP615 Portable DVD Player
I have a Zenith DVP615 Portable DVD Player when i put a disk in it says check disk but will not play, the disks are fine but no play.
Hello
In this case maybe you have defective Ribbon wire or defective Lens,.
ok Please clean the lens with 100% cotton first, if not reading after you clean the lens, kindly replace the ribbon wire, then test run, if not reading again replace the lens you have defective lens..
Thanks
Angel...
Sep 19, 2009 | Zenith DVP615 Portable DVD Player
Hello my Dell Studio 1435, it can read CD but not reading DVD... it give noise when i put DVD..
Try using a good quality DVD cleaner first. The lens for cd/dvd are different so one may work if the other is dirty. If cleaning does not work then the dvd lens may be out of alignment or broke. With today's prices it is cheaper to replace the drive $30-40 than try to repair it. Hope this helps.
Sep 11, 2009 | Dell Studio 15 Laptop
Dell Inspiron E1505 CD/DVD Drive reads only dell disks.
If the driver didnt fix your problem, your disk drive might be faulty , maybe the problem is on the disk drives lens this is very common problem 2 any other cd/dvd rom drives.
Jun 26, 2009 | Dell Inspiron E1505 Notebook
DVD ROM can play CD, but not DVD
try with next dvd which is burnt in less than 16x speed then check what happens.
Jun 02, 2009 | ASUS (E616P2) Internal DVD Drive
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
My dvp615 doesnt want to read any cd or dvd
Try using a dvd cleaner on the lens. If that does not work some people use a q-tip with a little rubbing alcohol on it. If niether of those work then the lens is not dirty but broken and will have to be replaced. Any other questionsjust give me a shout.
Jul 30, 2008 | Zenith DVP615 Portable DVD Player
Zenith DVP615 Portable DVD Player Logo
107 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
