Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
My mitsu ws-55315 tv
Would i have zero glare if i took off the plexi glass? do i absoutly need the plexi glass?
  • Anonymous Mar 14, 2014
    MODEL P52927
  • 927 Answers
Good Day;
Simply, NO!
Big Irish.
Posted on Jul 02, 2008
Ws-55315, screen turned to fuzz
If it was the lamp there should be nothing. press the menu button if the menu does not come up the issue is with the tv. If the menu does come up try a second source a dvd player or game system. If the issue is only with the original source than the original source needs to be replaced.
May 05, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
I have a mitsubishi ws 55315 and i need to program my remote to the att uverse motorola cable box.
hi i have a couple of codes here for your mitsubishi tv just try them 0005 0151 0051 0004 0009 0254 0022 0141 0180. hope this would help! goodluck!
Sep 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Protector glass on a mitsubishi 55in hdtv 1080 #ws-55315
I have the same tv and I took my clear shield off and never put it back on.  The picture is much better without it as it will reflect light and objects in the room making it difficult to see the pic clearly.  I was told by a service tech that the primary purpose of the glass or shield is to prevent damage to the screen from objects, water etc.  If you have no small children in the home you can enjoy a better pic.
Dec 26, 2008 | Mitsubishi WS-55315 55" Rear Projection...
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
