Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Loud humming sounds.I do not think anything is jammed. Cannot reset!
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Sep 30, 2010
Humming loud noise
Sometimes depending on what type of tire you have, they can be making the humming sound, other than that you'd have to give more detail as to where you think it's coming from, like the back or the front, the engine or the wheels, transmission?
Jul 02, 2014 | 2005 Ford Escape XLT
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Loud HUM from 1963 Wurlitzer 2710 when plugged in
If you observed a vacuum tube with the symptoms you describe, it requires replacement but there may be other failed components as well.
Dec 27, 2013 | Audio Players & Recorders
I keep hearing a weird humming sound from rear passenger side
make sure your tire is ok and is not r ubbing on anything and check your drivetrain ujoint`s etc.
Oct 07, 2009 | 2003 Ford Mustang
Loud annoying sound when driving over 35 mph
Check the fluid level and make sure. If the fluid level is not the problem, I would have someone do a complete check on the front end.
Jun 01, 2009 | 2003 Toyota Corolla
Hotpoint side by side refrige problem
Sounds like the gear jammed , replace the ice maker for a fix.
Apr 10, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker does not despence ice
thanks for the question if it only clicks & a hum its jammed if a click but no humm it could be the motor remove the motor and give it 110 volts on the bench this will tell you thanks the appliance doc
May 13, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag 100 series
If the unit is just humming and then cuts itself off, you could have a defective motor. However, this same symptom could be caused by something being caught in the pump assembly.
Sep 29, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
513 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
