Question about NetGear WGR614 Wireless Router
How do i change my security key password - NetGear WGR614 Wireless Router
    Genius:
  • 1,354 Answers
Go to folowing link it as a complite setup infromation it will help you to change your security
http://kb.netgear.com/app/answers/detail/a_id/120
Posted on May 13, 2010
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
What is the security key of netgear wireless connection?
Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
Aug 16, 2010 | NetGear WGR614 Wireless Router
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
HOW DO I SET SECURITY ON ROUTER
Open a browser window and go to 192.168.1.1. At the user/password screen, leave the user blank and enter admin as the password. (This is assuming you've never changed the settings of the router). On the router webpage, click on the word Wireless at the top of the page and then click on the word Wireless Security under that. Change the security mode to WEP and select 128 bits in the drop down beside WEP Encryption. Now enter a passphrase in the passphrase box and click generate. The key 1 is what you'll need to enter into the wireless devices when prompted for a access key. Now, you want to change the default password to get into the router so someone cannot easily come and change your settings on you. Before you leave the Wireless Security page, be sure to click save settings. Once you are able to get back into the web page, click on administration at the top of the page and change the password for the router and click save settings. Your router is now set up for security. Be sure to keep the key, passwords, etc. in a safe place.
Jan 27, 2010 | Linksys Wireless-G WRT54G Router
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
My spouse changed my security and phonelock codes
Try this out:
  • Press Menu
  • Use the Navigation Key to scroll to Settings and press the Center Select Key
  • Use the Navigation Key to scroll down to Security and press the Center Select Key
  • Use the Navigation Key to scroll down to New Passwords and press the Center Select Key
  • Use the Navigation Key to scroll down to Unlock Code and Press the Center Select Key
  • Press the keypad to Enter Old Unlock Code (Default 1234) and select OK by pressing the right soft key. If you have forgotten the unlock code, press Menu and enter the Security Code (000000)
  • Press the keypad to Enter New Unlock Code and select OK by pressing the right soft key
  • Press the keypad to Re-enter New Unlock Code and select OK by pressing the right soft key
Nov 10, 2009 | Motorola Mobility RAZR V3m Cellular Phone
192.168.1.1 gateway forgot how to change password and would like to have wireless password protected
The router's default password is admin without username. If you want to enable the wireless security, go to Wireless tab, then Wireless Security sub-tab. On the Security Mode, select WPA-Personal and type in your password on the Shared Key or Passphrase box. Save settings. That should do it. You wireless security key is the one that you type on the Shared key box.
Oct 23, 2009 | Linksys Wireless-G Broadband Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
