Question about Invicta 2302 Wrist Watch
Model 2302 how to back up date?
Model 2302 how do I back up date? Do I need to roll forward until correct date appears? Can't determine if stem has positions allowing such adjustment and I don't want to unscrew the stem. Thanks.
    Scholar:
  • 93 Answers
You should not be able to unscrew the crown from the stem by turning in either direction. So don't worry about that.
If your watch only has a date then you can "quick" change it by pulling the crown out to the first click and turning the crown. One direction will change the date. If your watch has both day and date then one direction will change the day and the other will change the date.
You will have to go forward counting the date upwards. You won't be able to make it go backward.
Once you have the date set push the crown back in and if it screws down be sure to screw it down so it is sealed.
Hope this helps,
Ken
www.yellowstonewatch.com
Posted on May 13, 2010
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
How to set day and date on a Benrus quartz watch model # BN529? Has one stem with two pull out positions. The first position only changes date going only in direction.
Typically, you need to run the time around until the right day is up and the right time is set to am or pm. Then turn in the other stem position until the correct date shows up.
Jun 26, 2011 | Watches
How do I adjust the time and date on my Timex Expedition watch
Hi, the upper of the two watch stems is turned counter clockwise (looking at the stem) until the desired function (i.e., format, date, time, chrono, timer) appears. To set that function, pull the upper stem out and turn CW to advance & CCW to go back. Once hours & minutes are set, the stem can be pushed in upon a mark to start at zero seconds. For the day of the week, turn the upper stem CCW until date appears. Pull out the stem, to detents or positions, and this will allow the day to be adjusted.
Take care
Mar 25, 2010 | Timex Expedition47761 Wristwatch
Cant set the date to one day before
Pull the stem out gently until it clicks once. Turn counterclockwise until the correct date appears. Pulling the stem out to the second/last click adjusts the time.
Jan 15, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
I have a citizen eco drive watch.. the day is 17 when it should be 16. How do I set to the correct day of 16 ?
When you pull the stem out it should "click" once to adjust the date and pulled farther to adjust the time. Pull to the first click and rotate counterclockwise until the correct date appears. push stem back in.
Jan 15, 2009 | Watches
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 | Watches
I have a pre-owned but mint condition 18K two-tone Cartier Panther watch with the date in the 5'o'clock position. The date currently reads the 18th, but today is the 11th. Is it safe to pull out the stem...
hello,
first give the answer carefully
is you have a problem to set your clock.......
if yes..
then watch these video and tell me is you have the same problem
IF ANY DOUBT
contact me
Jul 11, 2008 | Cartier Watches
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Operating instructions for a replica Rolex oyster perpetual cosmograph daytona watch
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Apr 22, 2008 | Watches
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Invicta 2302 Wrist Watch Logo
191 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
