Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Small bar on tiller to make it go forward and reverse broken so no way to control start and stop. Also, free wheel is broken and scooter moves when in stop mode or key is removed. can I still use it, repair tech wants $1020.00 to fix an 8 yr old scooter
  • 177 Answers
Hi. Are there other faults as well? Maybe you should get another quote from a different technician, or ask him if he has any second hand parts available.
If you use it, and you cant control it, you end up down a bank or under a bus.
What brand and model is it?
Sometimes the brake disc in the brake unit splits and allows the machine roll on. Sometimes the brake lever has had a bump, and just needs to be pushed back into place properly.
Try contacting the authorised service people for this scooter, and get some prices from them. Good luck. Neil.
Posted on May 29, 2010
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Has NO reverse but goes great in forward help
This sounds like the Wig-Wag could be at fault or the wiring to the controller.
Apr 06, 2015 | Shoprider Mobility Products, Inc. Hero...
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
User needs to use left hand for forward and reverse and would like wires switched
hi, you need to expose the throttle pot that is the pot attached to the lever you move to go forward or backwards, normally it a top cover known as the tiller cover, once you done that you see the throttle pot has three legs with coloured wires attached now you need to crossover the outside wires, not the centre one, by doing this you're are moving the reserve to the right hand side and the forward to the left hand side.
if you require more assistance then please let me know..
that's it,
regards
please give me feedback
Dec 17, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
From willaston auto electrics adelaide , customer brouht in a pride pathfinder 4 wheeler no forward or reverse movement, has power to volt gauge, horn works, any suggestions appreciated
neville the problem could be numerous things but lets try the simple ones first. a bad throttle pot or speed control pot can cause that problem. Both of those are located in the tiller console and that has to be removed to test them. You can ohms check both with power off and you can voltage check them with power on. You should get a smoth change in resistance as you turn th speed pot and as you move the throttle forward and reverse with power off. alsdo chech the connections in the tiller and remove the seat and battery cover and check the connections at the rear of the scooter sometimes just moving the wires can get it moving again but that won't help you locate the problem if you can't isolate the bad connection or bad wire. Scooters are tough to repair because of the many connectors that they have and the cables runnig front to rear that can cause problems especially with Pride scooters Good Luck I know I didn't give you much but I'm not fond of working on scooters Hope this Helps
Oct 12, 2010 | Pride Mobility Products Victory 9 Scooter...
The Pride GoGo 4 wheel scooter does not move forward or backward. when the key is turned on the batery meter displays a full charge. When the forward or reverse lever is pressed the unit beaps numerous...
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
Jun 11, 2010 | Health & Beauty
Start & stop , Kind of willy nilly.
hi, it could be the speed pot or wig wam as it called , try moving it at a angle to see whether it goes okay
Jun 30, 2009 | Pride Mobility Products Go-Go Elite...
My troy bilt won't go in neutral
The Junior tiller does not have a neutral selection. In order to free wheel the tiller you have to remove the pins that go thru the wheel rim hubs and then it will roll without starting it. Hopefully the rims are not rusted to the wheel shaft.
Frank
Mar 30, 2009 | Garden
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
146 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
