Question about LG Flatron L1919S LCD Monitor
SIR I have a lg 19 monitor having problem is
SIR I have a lg 19 monitor having problem is one hour other wise half hour after automatically will off but cpu is running after on off the power button of monitor and then ok but i no keping any screen saver and also power options also i checked it is never all . pls reply me as soon as possible
  • 3,083 Answers
It sounds like the monitor is shutting down after you have it on for a 1/2 hour or hour, is that right? If so, and you can turn the monitor off and back on, and it's ok again, that means you probably have a temperature problem with some component in your monitor. It will have to be serviced and troubleshot to get it working again. You can use it the way you're doing now, and it will probably work like that until you can get it fixed. Make sure you get an estimate from a repair shop first, because often the cost of repair can be almost as much or more than a new monitor. Good luck, and hope this helps.
Posted on May 13, 2010
Monitor will not go on or off, no power at all. checked all connections. I have a lg flatron 4 ms 1400-1, purchased in 2006.
Sounds like the power circuit on the monitor is bad, this is not user replaceable.
You can try letting the monitor sit for a few hours and trying again, as sometimes these monitor can overheat but this is a less likely reason for your issue.
Mar 15, 2011 | LG L1915S 19" LCD Monitor
Sir i had purchased 20 "led LG monitor B4 15 says.Now there is white , blue vertical lines in the led monitor. What is the problem
The monitor is defective and it needs to be repaired or replaced. Contact the place of purchase or the manufacture.
Feb 28, 2011 | LG L1915S 19" LCD Monitor
Sir i got a viewsonic lcd 19" model 1918 it
Let the unit cool down for 30 min., give proper ventilation because your processor have a heat sensor, once reached the peak temp the unit will automatically shuts off. Keep away all the obstruction from your vent.
Let me know if the symptom is still there...
Thanks for using fixya.
Feb 02, 2011 | ViewSonic VX910 19" LCD Monitor
Sir i have a 19" LG
To change the resolution, right click on the desktop and select properties, then in the settings tab, select the resoloution you would like. Normaly 1024X768 or 2180X1024. Depends on the monitor but I would say 1024X768 with 32bit colour.
Otherwise if is 1024X768 is not supported then it is a Graphics driver problem. Download the latest Nvidia drivers for your Graphics card by typing the model into google.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | LG Flatron L1750S 17" LCD Monitor
Blinking
change all control panel switch in frount
Mar 19, 2010 | ViewSonic VX924 19" LCD Monitor
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Colored lines down the right side of monitor.
Sir
It seems that the lcd screen was damaged you mentioned something fell on it and damaged the lcd. You would need to replace.
Feb 12, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
LG Flatron L1919S LCD Monitor Logo
78 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
