Question about Kenmore 62602 Electric Dryer
Won't heat Fuse and element both test ok. Both thermocouples on the side of the element housing show continuity as well
  • 109 Answers
Make sure you have 220 volts to the unit.
Posted on Mar 30, 2008
SOURCE:
I replaced the heating element and my dryer still won't get hot I have kenmore dryer
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Dryers
Kenmore series 80 electric dryer won't heat
May 28, 2012 | Kenmore Dryers
Kenmore dryer not heating
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 28, 2012 | Kenmore Dryers
Dryer not heating up
Apr 24, 2012 | Whirlpool Dryers
My kitchenaid dryer won't heat up.
Dec 31, 2011 | KitchenAid Dryers
Not getting heat
Hello there mark and welcome to fixya
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, you will need to test it for continuity it should read 000 on the meter if good and a 001 or a 1 means bad ok the meter needs to be set at the lowest ohms scale . Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 17, 2011 | Whirlpool Dryers
LG electric dryer is not heating. Electric coils test for continuity. Any suggestions?
There are several things that can prevent a dryer from not heating. UNPLUG DRYER BEFORE TESTING ANYTHING.
1- power- Test the receptical to make sure you are getting 220 volts. To do this you need and voltage tester. Both legs should pull 110 and together 220. If one leg is not pulling any power than your breaker is half tripped. Reset breaker to cure your problem. If problem persist it is in the breaker or receptical.
2- cord- To test this unplug dryer. Take the panel covering the cord connections off. Remove cord entirely from dryer. Test each leg for continuity. If any are not showing cont than replace cord.
3- Themal fuse- To test this remove access back access panel on some front panel. By the blower housing there is a fuse white thin sliver or round fuse with 2 wires going to it. The one with 4 wires is your low limit cycling thermistat. The thermal fuse is near that. Disconnect the 2 wires and check fuse for continuity. If meter shows cont fuse it good. If not replace fuse.
4- Hi Limit Thermistat- test same way as thermal fuse. On the heating element housing at the bottom are 3 wires running to a fuse. Test the left and right. The bottom is attached to one of the sides.
5- Thermal Cutoff- Test same way as thermal fuse. This fuse is near the top of the heating elemnt above the Hi Limit. 2 wires with usually plastic covers on them.
6- Heating Element- Below high limit 2 wires. Test for continuity.
If all these fuses are good than you may need to call a technician. The motor may not be getting to the right rpm to activate the senfrigrial switch in the moter. Timer or control board may be out.
7- Motor- If
Jul 16, 2011 | LG DLE2514 Electric Dryer
How do i troubleshoot my kenmore model 110 electric dryer. it does not heat while it tumbles. How do I know for sure that it is the heating element.
ok first unplug dryer on the side of the heating element housing you will see the high limit switch black plastic with a sticker and a metal nose pull the 2 wires off check for continuity with ohm meter should be closed if it reads closed put wires back. Now look for a white ceramic rectangle piece it is a thermal fuse pull the wires and chech continuity if it shows closed it also is good. if either of these show open they need replaced. Now if both showed closed unplug wires from heating element check continuity should read continuity. if open element is broken. Now assuming this all shows good. Then it could be the timer or the centrifical switch on end of motor.
Jan 08, 2010 | Kenmore 84832 Electric Dryer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire front load elecrtric dryer runs but no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 03, 2007 | Frigidaire GLEQ942CS Electric Dryer
Kenmore 62602 Electric Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
