Question about Car Audio & Video
Unsure about what wires to connect. - Car Audio & Video
  • rwhcc May 13, 2010
    How do I install a XR4110 Digital Media Receiver into a 2000 Saturn SL? What wires do I use?
  • 154 Answers
Im not clear on what your trying to do here. are u putting in a new radio? if thats the case you need to buy a wireing harness and then all you do is connect all the wires to the same colored wires. then click them together. .let me know
Posted on May 13, 2010
  • dave taylor May 13, 2010
    ok if you go to walmart and get a harness to your year car which will look like this.
    then you will take and connect the black wire to the black wire orange to orange and so on until there are no wires left then just click the two connector together and you can turn ur car on acc and test the radio to make sure everything is hooked up b4 you reinstall the radio incase a wire isnt hooked up you dont have to re-disconnect everything. also if you cant find the harness at walmart i found one for like $13 on this website http://www.amazon.com/Chevrolet-Saturn-R... goodluck
    Genius:
  • 1,040 Answers
Dear Rwhcc,
visit to the given link. there are diagrams with the explanations.
http://www.the12volt.com/caraudio/woofer_configurations.asp
For quick reference visit to following link.......
http://www.ehow.com/how_5829_wire-car-stereo.html
Wiring diagram for a Kelvinator 330
There's only 2wires and it shouldn't matter which terminal on the cold control u connect it to. If there's 3wires one should b green and it's a ground wire
Nov 30, 2013 | Electrolux Kelvinator Cyclic Defrost...
Renault scenic diagrams
thats the thin wire i presume and it goes to the small terminal on the starter motor solonoid ,if you unsure then ask a local mechanic to have a look for you
Nov 22, 2013 | Cars & Trucks
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Having to replace 3 wire power cord with four wire and can't find manual and unsure how to connect propperly.
Connect the colors with the colors on the dryer wires Black with black, White to white, and red to red. The green wire gets attached to the dryer cabinet on the screw on the outside of the access hole on left normally. on the exterior of the cover. Give me a rating if I helped you. Good luck!
Aug 22, 2010 | Maytag MDE308DAYW Electric Dryer
3 prong connection to fusebox using hot wire, neutral wire, and ground wire. I know the hot wire and neutral wire connect to the circuit breaker, but I'm unsure about the grounding connection.
There will be a ground log/screw somewhere in the panel box. The ground wire goes to that.
If you see other bare wires going to a screw in type attatchment that is mounted to the panle box without insulators, that is the ground mount.
Oct 03, 2009 | Dryers
Re-wireing of plug cord
green color wire to the top center. then brown to the fuse, the rest is blue wire.
Jun 14, 2009 | Heating & Cooling
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 | Cooktops
Unsure if spark plug wires are connected to the coils correctly
i presume what you replaced was the coil pack. if it's a six cyclinder which my windstar was... the numbering on the pack is one to three on one side. and 4-6-5 on the other. either ford had a better idea or they wanted to see if mechanic paid attention. you haven't mentioned the motor is running rough, but the spark sound suggests something is off. start from the coil pack and make sure each wire is where it should be. it's numbered right on the pack. the wires hopefully will have numbers stamped right on them.
follow each wire to see which cyclinder it goes to to make sure the order is correct.
Robert
Dec 16, 2008 | 1997 Ford Econoline
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
