Question about Electrolux Guardian Bagged Canister Vacuum
A sock is stuck in the nozzle. won't come out . how do you take it appart?
  • 50 Answers
Remove the power head from the wand. Turn it upside down on a table or counter. There are 5 screws to remove to take the head off. There are
3 on the long part just in front of the brush roller and 2 more on each corner of the short part. Once you have the hood off you will be able to remore your sock, then put back on the hood.
Posted on May 13, 2010
Sock stuck
About the only other place it could be so in the tube in the power nozzles which can be removed. Take off the bottom plate to access this area.
Dec 28, 2011 | Riccar 8955 Upright Vacuum
I got a sock stuck in the hose how do i get it out?
Take a metal closthes hanger and undo the hook end from the spiral at the base of the hook, leave the hook and the coil that held the hanger together as is and straighten the rest. Put the spiral end of the hanger into the hose, when it reaches the sock twist the hanger to screw the spiral into the fabric, not too far, only a little. If you have enough grip on the sock, it should pull back out. You may have to try several times until the sock pulls free. Good luck.
Feb 04, 2010 | Kenmore Vacuums
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Clogged hose and can not get the handle off
The best way to fix this problem is to Stick the other end of the handle into the wall inlet making the nozzle contact the pin jacks of the wall inlet. You may need to work the clog back and forth by then plugging the hose in normally. Eventually you will be able to work the clog out of the hose.
If all else fails you should use a plumbers snake.
Jan 06, 2009 | Electrolux Central Vacuum
Sock stuck in hose
Yes there is a small clip on the purple/yellow part on bottom of hose. its hardly an inch thick pll back on the tab and up on the hose
Oct 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stuck sock
first off how did u get the sock that far..lol but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Dec 30, 2007 | Electrolux Lux 5500 Canister Vacuum
Sock stuck in the vacuum
My fan changing guide will lead you through the process of taking the vacuum apart to get to the sock (if it is still in there)...
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Hope this helps,
Marci
Nov 25, 2007 | Kirby G4 Bagged Upright Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
113 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
