Question about Ariens 34 In. Zoom Series Riding Mower
Can I use leaded gas or only unleaded - Ariens 34 In. Zoom Series Riding Mower
    Scholar:
  • 108 Answers
Check with your owners manual. But as a former lawn professional, I only used Premium fuel in my Scag zero mowers. You should however use ethonal free fuel if you don't run at least a tank a month through it or you can buy Marvel Mystery Oil as a fuel additive to help keep your motor clean and running smooth. I use Marvel Mystery Oil in the boat, mowers, and 4 wheelers. Works great. Ethonal free gas is hard to track down so this is a great alternative.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Posted on May 14, 2010
What type of fuel does it use unleaded or leaded
Dude you don't say what car so
1900 to 1904 Kerosene
1904 to1976 Leaded gas
1976 to present Unleaded gas
Mike
Apr 06, 2016 | Cars & Trucks
What fuel? Unleaded or leaded for a porsche boxster 1999
All Porsche petrol engines have been unleaded since 1990
Mar 16, 2015 | 1999 Porsche Boxster
Can I use unleaded fuel in my 1972 3hp engine
Lead is basically a lubricant with additional octane boosting properties for gasoline powered internal combustion engines. Engines intended to run with leaded gasoline that are provided with with unleaded gasoline instead are subject to overheating and failure. Read more about lead here:
Why Lead Used to Be Added To Gasoline
Your best bet would be to use leaded gasoline - or in the absence of a leaded gasoline source, a lead additive or substitute. Most autoparts stores sell this - and if you're not near one that does - Amazon has it:
Amazon com lead additive for gas
May 13, 2014 | Briggs & Stratton Hammering
Petrol and oil
You can use either leaded or unleaded, it depends on your laws for pollution. Oil is 32 parts gas to 1 part oil also known as 32:1
Jun 07, 2013 | Motorcycles
Can 94 jetta run on leaded or unleaded petrol
It is best to run this engine on unleaded petrol. A high grade unleaded will give you extra performance and cause no damage. Leaded fuel was designed for cars made in the 60's to 80's that had used softer materials in their cylinder heads, leaded fuel pro-longed cylinder head life and reduced pre-ignition. Unleaded fuels are a cleaner, safer fuel to use.
Jan 24, 2011 | 1994 Volkswagen Jetta
I have a Isuzu D/C 4x4 KB 260 1997 Do I use unleaded or leaded petrol
I am assuming since you posted this question you are not US based where leaded petrol has been phased out since late 70's. The Isuzu KB260 truck was manufactured to use Unleaded petrol. Lead was added to be a lubricant in older engines that were hand machined in factories LONG ago... the valves and all werent as close in tolerance and the lead in teh gas helped keep them in shape. Newer engines, such as your Isuzu, utilize computer machining during assembly and the tolerances are more precise....so the lead is not required. Be sure and use Unleaded in your vehicle.
Aug 14, 2010 | Isuzu Pickup Cars & Trucks
Craftsman SnowBlower
The term "Unleaded gas only" refers to the type of gasoline to be used. You would use "Unleaded gasoline" instead of "Leaded gasoline". Yes, you will mix oil with the gas normally at a ration of 50 to 1. (1 pint of oil to 6 gallons of "Unleaded Gasoline"). If you do not put oil into your gasoline, you will burn your engine up due to lack of oil. I hope this helped, Good Luck Please rate me, Thanks
Dec 25, 2009 | Garden
What type of petrol should be used in a 1981 honda cbx 1000 Unleaded, or unleaded with lead replacement additive?
by the 80s all lead had been removed from gas. i know of no manufactuer that hadnt made the switch to hardened valve seat by then
Nov 28, 2009 | 1981 Honda CBX
My cng truck runs fine on nat gas,when switched back to unleaded gas truck stalls,what is the fault ,how is the two computers controlled,what deos the switch turn off.
tune up for gas is different in the timing compared to lead or unleaded fuel by upto 12 degrees
the two computers control the engine management & the transmission
when you switch between nat gas & fuel a solenoide is activated to block ether so they cant mix
if they did mix your gas would freeze the fuel & you would see the fuel pipes start to get iced up
Cheers Rob
Jul 29, 2009 | GMC Sierra 2500 Cars & Trucks
Ariens 34 In. Zoom Series Riding Mower Logo
211 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
