I have a mitsubishi tv model# 40505 serial # 508621 and the tv is set up to use external speaker and I would like to change it to internal speaker, I longer have a manuel and do not know how to make the change. Please help e-mail grupotaino@hotmail.com
  • grupotaino May 13, 2010
    thats the problem!!! how do you unplug the speaker,, taking it out did not help,,,how do you get the tv to change from external speaker to internal spkeaker,, it does not give an option to select ( turn on internal speaker).
  • 56 Answers
Unplug the external speaker
Posted on May 13, 2010
Model TH-42PV7MR. How do we change sound settings from internal speakers to external amplifier?
Go back to the initial set up where you may find the option to disable internal TV speakers and direct audio to an external amplifier.
Nov 24, 2015 | Panasonic Televison & Video
Mitsubishi 72 inch TV speakers turned off no
Was it bought used? Did you check the settings? If it was used with an external receiver the speaker settings may have been changed to not use the internal speakers.
Sep 21, 2014 | Televison & Video
I have perfect picture but no sound??
Many Mitsubishi TV have an audio mute button on the back of the set. It is near the audio out RCA connector and is used to disconnect the internal speaker when an external speaker is used. Just press the button and the internal speaker will work.
Sep 16, 2013 | Mitsubishi WD-73638 DLP TV
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Tv has no sound
check your menu and make sure your speakers are on for the tv. also make sure your connections to the tv- have audio going to the tv. on certain tv's they have an internal-external manual swith on the back of the set that could be in ext instead of int-if so switch it to int. beyond that you need to call for service.
Apr 21, 2010 | Mitsubishi CS-40505 TV
No sound coming out of my Mitsubishi Model CS-2013R (older model). Picture is still great. Just no sound all of a sudden. TV nor DVD player (running through it) project sound...
The older TV's have a switch in the back what if bumped will cut the speakers off. It is for internal/external speakers. Check the switch & make sure it is set for internal speakers. If that still does not solve it, go to your Menu screen advanced options and make sure the speakers are turned on. If it is and still not audio, then you may have a problem with the internal amp or the audio switcher. Note you will need the factory remote for the advanced options
Nov 08, 2009 | Televison & Video
How do you unlock a mitsubishi tv CS- 40505 without the original remote?
i have a mitsubishi and a phillips universal remote , someone locked my tv don't know password
Oct 22, 2009 | Mitsubishi CS-40505 TV
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
