Set password how di I set a password
    Brigadier General:
  • 10,406 Answers
Connect an Ethernet cable between one of the LAN ports on the router to the network-port on your computer.
Click Start
Click Run
Enter CMD
Press Enter
Enter IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 264.368.452.321
Start Internet Explorer
Enter http://264.368.452.321
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Network Setup Wizard"
Choose a security-level (at least 'WPA') and choose an SSID and choose a password.
Click OK to commit your values
Posted on Jun 17, 2010
Hw to set wirless password :/
Using your browser login into you router and go to the wireless section. There you can set or change the password. You can also use the set-up wizard to do this set-up.
Aug 24, 2013 | D-Link DI 514 Wireless Router (DI-514)
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
How do I Reset My Password in My D-Link DI-524? I've Tried the 192.168.0.1, but Nothing Happens, just keep getting the Password Re-Set window
If you forgot your password, you can reset the router to it's factory defaults (You will lose all your settings/changes you made).
You can go here to see how to do it.
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/
Oct 13, 2011 | D-Link AirPlus DI-524 Wireless Router
How to get pasward
According to the manual (http://www.dlink.com/products/default.aspx?pid=DI-514&tab=3) leave the password field blank and use the username: "admin" without the quotes.
This is the default username and password. Of course, change the password once you log in (since it has no password).
However, if this password doesn't work because it has been changed already, you can reset the router back to the default settings and password. Here's the details from the manual:
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
May 09, 2011 | D-Link DI 514 Wireless Router (DI-514)
Forgot my DI 524 setup password, pushed RESET button, what next?
You will need to login as admin and set it up again. Connect per ethernet cable, open a browser and enter 192.168.0.1 You should see a router welcome screen or logon dialog login as admin the default password maybe one of several things depending on the particular revision/edition blank/null 'admin' 'password'
Support for this model is available at http://www.dlink.com/products/?pid=DI-524&tab=3 manual at ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip
Once you're in you will have to set up an ISP connection which may require your ISP username / password and selecting a protocol particular to your ISP and setting up the wireless WEP key
Jan 08, 2011 | D-Link AirPlus DI-524 Wireless Router
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
D-link DI-514
The information he gave you was correct for a new DI-514 but if this has already been used it could be that the password was set. To take care of this problem, you can return the router to factory default settings by inserting a paper clip into the reset hole at the back (leave the router plugged in and turned on), hold it for ten seconds and then release. The router should reboot. Try the 192 and admin again.
Oct 17, 2008 | D-Link DI 514 Wireless Router (DI-514)
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
