Question about Nikon D80 Digital Camera with 18-135mm Lens
My D80 suddenly stopped taking photos while I was in Auto mode. I noticed the flash stopped releasing. I've changed lenses, reset the camera's green buttons, switched out the card, reset the clock. It will occasionally take a photo, not necessarily in focus,and the flash will on occasion pop, but I can't figure out what the correct triggers are. Can anyone help? Lens is 18-135mm. Set Lens in in "A" and camera is in "AF"mode. Thanks much.
    Champion:
  • Nikon Expert
  • 225 Answers
Hi, Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Posted on Aug 25, 2010
My Nikon D70 camera takes pictures that come out completely black
Check the MODE. With ANY camera with manual mode you can take black (underexposed) photos all day. If photos are black try and use an AUTO mode. Typical it has a GREEN Camera symbol. So many things can be set wrong on the camera and they are beyond this answer.
Feb 12, 2018 | Nikon D70s Digital Camera
Will not auto-focus in any mode
May need more detail, but D80 has a somewhat hidden switch on the body that takes it out of AF mode and into Manual. It's marked "AF" and "M". It's right under the lens release button, and sometimes gets switched by accident when changing lenses. Sorry if this is too basic, but without more detail it's hard to troubleshoot this.
Aug 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Unable to take photos. F stop flashing and r05 message shows.
do a reset in custom menu and you will be back to out of the box set up
Apr 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Dark photos
  • Be sure camera is set to the Green auto, not the A (A= aperture priority)
  • Be sure your white balance is on auto.
  • Be sure your EV is set to 0
  • Be sure your lens is on M/A, not M
  • Check the internal meter. See if it is showing a middle of the graph reading when the camera is on auto. If it is and you still get dark pix, might be time for Nikon repair.
Mar 12, 2009 | Nikon D80 Digital Camera
Hightlight message on Nikon D80
Highlight is just the info mode, there are several info modes including Basic file info, Shooting Info and RGB histogram, just press the round controller in the up or down direction to change between them in playback mode. Highlight will flash black anywhere there is pure white in an image.
Try resetting the camera by pressing the 2 buttons with green dots (on top of the camera near the shutter release) holding them for a few seconds.
Mar 08, 2009 | Cameras
My nikon d80 will take a picture in M mode only
there are 2 swtiches of the AF on the D80. 1st is on the lens itself and 2nd is on the left side just below the lens release lock. A/M .. set both to A for auto. cheers.
Nov 27, 2008 | Nikon D80 Digital Camera with 18-135mm...
Yellow/green tint indoor photo using auto portrait mode
Hi - You can download the Nikon D80 Guide to Digital Photography manual by clicking the link underlined in blue below:
Nikon d80
Firstly see page 58:
Try setting the white balance to fluorescent an compare. Also you could set your own white balance preset by shooting a white card as per page 59. Lastly you can play with the "tone adjustment" on page 80.
Let us know how you get on!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 11, 2008 | Nikon D80 Digital Camera with 18-135mm...
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Jun 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
HELP Sigma 24-60MM wide Angle
The helicoid or the barrel thread in the lens may be jammed. The lens will have to be serviced. You should take it back for warranty service.
As for myself, I aways buy origional manufacture lenses and accessorites for my cameras.
Jerry G.
Jun 06, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
97 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
