Question about HP Compaq Presario R4000 Notebook
USB Problem The bubble USB devices not recognized appears when I plug in plug and play devices. I had a live chat with HP tech and I down loaded the chipset driver, this did not work! Any Idea how to solve this problem. Rob.
  • brian c
    brian c May 11, 2010
    What kind of "device" are you trying to use?
    Guru:
  • 55 Answers
Sure.....
click on start...cright click on the computer.....select device manager......look for universal serial root hub start uninstalling all the root hubs from the botton and restart the computer and as soon u restart the compute tap F1 (if u r using xp) or tap F10(if u r using vista)it will open BIOS setup...go to the advanced option using ur right left arrow keys and look for USB legacy device using up and down arrow keys select the option and hit enter and ten select the option that says enable and hit F10 and then select start windows normally if the opyion pops up....now try....if the issue is still there pls mail ur query to gunjan37@hotmail.com
Posted on Apr 11, 2008
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
Software Loading / Scanner Recogniton
Several times, I've had issues installing USB devices on Dells.  The problem seems to involve the fact that Dell has trouble recognizing the ports as USB2.  It'll recognize devices, but not all devices, and not all devices will work properly.
I know this doesn't exactly solve your problem, but I thought this tid-bit might bring you a little closer to a solution.
Oct 30, 2007 | HP Officejet Pro L7680 All-In-One Printer
USB Device Not Recognized...
Your headset is faulty. Open it to check for loose wires.
May 28, 2009 | Logitech ClearChat Pro USB Headset
Vista/usb problem doesn''t run
You may have to load it manually through control panel with the disc..sometimes Vista/XP may not recognize the device during plug and play..if you have any questions let me know
Mar 27, 2009 | HP Office Equipment & Supplies
Installation problem
1. Remove the software from your pc
2. Restart the pc
3. Plug in the printer
4. When pc recognizes it
5. Install disc
If this is too vague, please go live chat. If it worked, please rate as a fixya. Thank you
Jan 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
The main reason for getting this message is that the USB chip or part of the connection to the chip has failed. The best way to test to see if the product is defective is to try it on another computer.
This will tell you if the product or the computer port has failed.
Sep 14, 2008 | Logitech ClearChat Pro USB Headset
"USB Device Not Recognized" - any usb device
Hardware to old or a spontaneous defect ? Burn a free linux live dvd ( mint or other live distro) to recognize a good working device.
Boot on cdrom and see what happens.
DistroWatch com Put the fun back into computing Use Linux BSD
Mar 08, 2017 | Electronics - Others
My Dell Dimension 2400 does not recognize plug & play for my HP OfficeJet Pro L7650 all-in-one. If I add the all-in-one manually, the computer says it's offline. I've uninstalled & reinstalled the...
My solution was very simple...I just threw my computer out the window! Seriously, the problem has not been resolved...it seems that several types of Dell computers (in my case, the Dimension) have a problem with HP all-in-ones with regard to the USB 2.0 having enough power to recognize the plug and play option when installing the HP product. Dell's only solution (that I could find) is to operate the HP product thru a USB hub...so I guess I'll try that first and, if it still doesn't work, I'll probably just upgrade to a newer non-Dell Dimension computer.
Jul 15, 2008 | Dell Dimension 8200 PC Desktop
USB
yes what is the usb device and the os
Mar 30, 2008 | HP Compaq Presario R4000 Notebook
YP-U2J MP3 PLAYER
hmm i got the same problem as jenn1519 ill plug mine in and when i usually plug it in the computer makes a bing noise like it recognizes that its in the usb plug but 2 seconds later it will make the bong noise that i unplugged it which i didnt so i cant put any new music on. it will charge but it wont let me get any music on. and windows doesnt read that its in there.
and also my mp3 player is very important for me its a gift from a friend so plzz plzz help ? :(
tanko!!!
its ma emil add hot_chilligirl@yahoo.com.au
Sep 11, 2007 | Samsung YP-U2X Digital Media Player
Computers & Internet Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
