I want to know how to set the speed dial - Office Equipment & Supplies
    New Friend:
  • 116 Answers
Which brand machine????????
Posted on Jun 14, 2010
How of you set up speed dial?
We cannot help you unless we know the correct model/platform of your phone. In general
In nokia phones, you can call 1-9 and it will ask "speed dial not assigned. do you want to assign it now?". Select yes, and now you can add a contact to that speed dial number. Note that usually, digit O in speed dial is reserved for voice mailbox number.
Nov 28, 2012 | Cell Phones
We have a new wx345 cell phone that we have set up with speed dial numbers but I do not know the procedure used to call or dial any of the speed dial numbers. Can you help us use our speed dial?
If you have set up your numbers with speed dial, make sure the speed dial option is set "ON". When you are ready to make a call, press and HOLD the speed dial number you are calling. I had the same problem and found the solution on another online forum.
May 20, 2011 | Cell Phones
How do i set up the system for speed dialing?
Would need to know the phone model, there should be a way to set previous called numbers to a digit speed dial 1-10 etc. If you have a smartphone, Iphone does speed dial as favorites which are set up in the call menu. Droids have a specific icon for speed dial.
Rylan
Dec 16, 2010 | Cell Phones
Using speed dial with an LG Neon
if you already have contacts in your phone book and you have follow the set up info given...its just like retrieving your voice mail you normally would press the number "1" key...lets give it a test run press the number 5 key down for a second or two and release...it should be dialing whoever is in the the #5 spot...you just place your first speed dial....try it again lets call that number 9 ...note you can always change the positions (callers) in your speed dial..just simply go to the phone book to who you want to replace (eg.you want replace Debbie #4, go to Sam... options/speed dial/ #4 this will over ride who is in that position)
Jul 03, 2010 | LG Cell Phones
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't delete wrong speed dials set up by my wife
You should be able to reassign the speed dials if you want to by going to settings/ speed dials.
Jun 01, 2009 | Nokia 1100
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
Setting the speed dial numbers
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Nov 03, 2008 | NorStar T7316E Corded Phone
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
110 people viewed this question
k24674
jasbo
jasbo
