I have a VGA distribution system that matrixes 4 computers to 4 displays (2 LED,LCD, 2 projection). Periodically, the VGA outputs go pink. The whole screen has a pink cast and little other color than black. We've mostly seen this from the Dell laptop docking stations. I cannot say whether either of the other 2 outputs have ever produced this.
  • 19,396 Answers
Hi.
The VGA transmits signal in RGB format. This means that the signal is split in Red, Green and Blue single channels, that are then put back together to form the picture on monitor display.
When the green channel is missing, the picture turns pink.
If the problem is on a sigle monitor, or on a single video connection, it can be the monitor or the cable. A defective part not working on green channel will in fact generate a dark pink picture.
If you use a VGA distribution amplifier, and the problem is happening erratically on all monitors, try replacing the connection cable from computers to the VGA splitter. A shorted input can mess up the whole system.
If that does not fix the problem, than the VGA distribution amplifier is occasionally failing on green channel and must be replaced. Here an 8 ports splitter: VGA Video Splitter / Distribution Amplifier 8 Port - 250.
Regards.
Ginko.
Posted on May 13, 2010
Why does my new ASUS VE278H have a overall pink screen color that won't go away with color adjustments?
You have a faulty/damaged screen but you might also check your video colour settings in windows/linux whatever OS you use
May 06, 2014 | ASUS VE278H 27" LED LCD Monitor - 16:9 - 2...
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
How to put tv in video mode instead of mono
I am confused wit the question. Mono is an audio setting. And video setting are for just that. video.
Mar 20, 2013 | Toshiba 40E210U LCD TV, 40 widescreen...
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
Can i hook up my 32 in emerson to my computer for netflix
Yes you can . Do the instructions below and then just download the Netflix movie like you would if you where to watch it on your PC. After all connections you should be able to watch it on your Tv screen, Enjoy.
Things You'll Need:
VGA to VGA cable
DVI to VGA adapter (as needed)
How to Connect a Computer to an Emerson TV
Purchase a VGA cable and a DVI to VGA converter (if needed). The VGA cable is a cable with blue attachments on either end that contains a total of 15 pins (arranged in a 5x3 lineup). You will only need the VGA to DVI adapter if your computer does not have a blue VGA connector on the back.
Attach the VGA cable to the VGA port on the back of your computer (going through the DVI to VGA adapter if necessary). When screwing the connector in, alternate between the two sides periodically. Tighten one side of the connector a little, then tighten the other side of the connector to match. This will ensure a tight connection and an optimal picture.
Attach the VGA cable to the back of your Emerson television, utilizing the same alternating tightening method that you used to secure the cable to your computer.
Use the menu button on the Emerson TV to select a new "source." Choose "VGA" input, then confirm that by pressing the OK button (normally the volume+ button on most televisions). The television should immediately switch to display the computer's output. If it takes you to a blue screen instead, simply restart the computer in order to reset the connection.
Feb 12, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have a HP Pavilion a6838F computer and I want to hook it up to my Hitachi 46" Projection TV (Model# 46GX01B). What cables do I need to do this. I want to watch movies, etc. on the big TV rather than on...
Warren:
Your PC monitor uses the 15 pin VGA connection for the output of your PC.
Does the Hitachi 46" have this type of 15 pin female input connection on it?
The problem is that I don't believe your Projection TV will display the output resolution that your PC outputs.
Many newer LCD or Plasma flat screen TV's have the VGA input feature's as they are made for High resolution inputs such as HDTV '1920 x 1024'
Sorry I just don't beleive that the TV will display the quality image you are so used to on your PC monitor.
Blessings,
A/V Media Guy
Nov 20, 2009 | Audio Players & Recorders
Screen keeps going black
check your numlock key presss it then check numlock led if it on /off then your computer gives dispaly to monitor perfact then when you power up ther computer press F8 key then enter in enable vga mode if you see safe mode and other mennu.
But if you can't able to see those menu then you have to check your monitor to cpu vga cable connection.
Also check your monitor is properly working? or not.
Aug 13, 2009 | Acer X193W LCD Monitor
Display is not the right color
This generally means there is a fault with the cable between pc and projector. If you have a spare VGA lead try it and see if that fixes it.
Also make sure that the cable is tightly pushed onto both ends
Jan 08, 2009 | Epson PowerLite S1 Plus Multimedia...
Computer monitor
I have never tried that but I would say it won't work that way. I have 2 display cards (3 outputs each, VGA, DVI, TVout) and 3 monitors. When I check the driver software and multiple screen function, it shows only 2 output (VGA and DVI) each. I cannot set TV output as a second screen. Even display properties on windows, it shows only available monitor output. I don't think you can do that.
Thank you,
Tan
Mar 05, 2008 | Dell E153FPc 15" TFT LCD Flat Panel...
Monitor is blank
You either have a bad inverter board in the unit or a lamp problem, also there are known issues with these units having bad capicitors in them. It is more fesable to replace it then repair it sorry :-(
Sep 15, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
