Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Heater Where is the defrost heater located at? And will it glow orange when it is defrosting?
    President:
  • 1,218 Answers
Good day,
Remove the rear panel in the freezer compartment. You will see the evaporator coil (cooling coil). The heater runs along the bottom of this coil. It is made of the same material a bake element in an electric range has.
While it glow? Not much if any on this model, but it gets quite hot during the defrost cycle.
Posted on May 13, 2010
106 76239402. It works fine but why have ice crystals formed around the back where it normally defrosts?
Sounds like you have a defrost issue. Remove the back panel inside the freezer and see if the evaporator is covered with a lot of ice, if it is then you have either a bad thermostat or bad defrost heater. If you have an ohm meter you can test the heater, use the sound version on the meter as it is much easier. If it beeps by touching one probe from the meter on each end of the defrost heater(You must first remove the wires in each end of the heater to get an accurate reading) If it does NOT beep then replace the heater and I would replace the thermostat as well as it is not that expensive.
Jul 27, 2015 | Kenmore Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
My kenmore refrigerator is glowing orange in the freezer.
That is completly normal, what your seeing is the glow of the defrost heater and its usually on for about 15- 20 minutes every 2-3 days,if you have your manual that came with the ref it will tell you that is't completly ok
Most people hear the term frost free but that is a misnomar and if a refrigerator isn't frosting it isn't working,their is manual defrost types that you need to defrost and automatic defrost types that a heater comes on and melts the frost after the ref. has for for appx 16 hours. Not 16 contunious hours but 16 hrs. of running (10 minutes on and 2 hours off takes awhile to accumalate 16 hours of run time)
Jul 26, 2011 | Kenmore Refrigerators
Coils freezing upevery 2 weeks or 3. goes upt to 48 in fridge ans 20 or so in freezer. runs great after i defrost it
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
May 30, 2010 | GE GSH22KGR Side by Side Refrigerator
Water in bottom of freezer
The red glow you see is simply the defrost heater doing its job. When the refrigerator defrost control senses it is time to defrost the evaporator, it turns on a heater that in the dark, can glow brightly. This is perfectly normal.
May 12, 2010 | Frigidaire Gallery GLHS38EE Side by Side...
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
Orange glow coming from inside freezer back of freezer warm
HI. that glow will be the defrost element. If that element continues to glow for a long period of time, longer than an hour, this will indicate that there are issues that concern the integrity of the defrost timer, or adaptive defrost control board. I would advise to shut off the power to the unit for five minutes. this will rest all the control boards that exist in the units structure. re-introduce the power to the unit, after the five minutes are up. If the element continues to glow, continuously, this will confirm that the defrost module has failed.(stuck in the defrost position). replace the either the defrost timer, or adaptive defrost control board(depending on the model), if the reset did not correct the issue.
Nov 14, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Orange glow in freezer, what is it?
Your refrigerator is a frost free unit. The derost cycle in a refrigerator is controlled by a timer or an electronic control. When a unit goes into defrost, the fans and compressor are turned off and a heater in the freezer is energized. This is the glow that you see, and the hissing sound is the water droplets, from the melting frost, making contact with the heater. This is perfectly normal.
Apr 27, 2009 | Refrigerators
Frosty
IS THE BACK OF THE FREEZER CLEAR ICE OR WHITE FROST?
IF IT IS WHITE FROST, THERE IS A FAILURE OF THE DEFROST CYCLE. THREE COMPONENTS NEED TO BE CHECKED. THERE IS A DEFROST TIMER, HEATER AND BI-METAL. THE HEATER AND BI-METAL ARE LOCATED BEHIND THE BACK WALL OF THE FREEZER WHERE THE FROST IS BUILDING UP. IF IT IS A WHIRLPOOL, THE TIMER IS LOCATED IN THE FRESH FOOD COMPARTMENT WITH THE COLD CONTROL. LOOK FOR A HOLE THE SIZE OF A DIME IN THE CONTROL HOUSING. THERE IS A SMALL DIAL IN THERE THAT CAN BE ADVANCED WITH A SCREWDRIVER.
ADVANCE IT UNTIL YOU HEAR A STRONG CLICK AND THE
REFRIGERATOR SHUTS OFF. THAT WILL BE IN THE DEFROST CYCLE. WAIT ABOUT TEN MINUTES AND LISTEN FOR SIZZLING IN THE FREEZER COMPARTMENT. ALSO LOOK FOR A RED/ORANGE GLOW IN THE FREEZER. IF THAT HAPPENS, THE HEATER AND BI-METAL ARE O.K.
REPLACE THE TIMER. IF NOT, TAKE THE BACK PANEL OFF THE FREEZER AND CHECK THE HEATER AND BI-METAL WITH A VOLT-OHM METER. REPLACE THE DEFECTIVE PART.
ON G.E. REFRIGERATORS, SOME HAVE THE TIMER LOCATED BEHIND THE TOE PLATE AT THE BOTTOM OF THE REFRIGERATOR. ON OTHER REFRIGERATORS, IT IS LOCATED INSIDE THE COMPRESSOR COMPARTMENT TUCKED BACK IN A CORNER.
Mar 31, 2008 | Refrigerators
Defrost heater
very possible thaT hte heater wont GLOW red. so long as its coming on nat all you r good. heater cant be half good its all or nothing
Mar 19, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
71 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
