Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence problem need the steps in locating and fixing this problem thanks Convergence problem due I think to distortion of picture - is straight across the middle but top of screen goes concave in the middle like a smiley face and at the bottom it is convex like a frown however picture still covers the entire screen. It started by being difficult to turn on and then once it was on it went funny. We tried to do the convergence of the colors, which worked a little but with the picture being distorted it is ok with color in the middle and then gets funny at top and bottom.
  • Judith Coleman Mar 29, 2008
    Link does not list these parts that you quote.
  • Anonymous Mar 29, 2008
    convergence problem
  • Philips Master
  • 8,617 Answers
The convergence ICs are located on the left board on a huge heatsink they should be STK392-110 or STK392-120. You can get replacement ICs at the following link and they also provide free step by step instructions on how to remove and install the new ICs.
http://servicemanuals.vstore.ca/
Posted on Mar 29, 2008
  • Sonny Berry
    Sonny Berry Mar 29, 2008
    Yes you have to click on the convergence IC heading in the left collum and you will see your part numbers.
SOURCE:
Thanks alot for yhe info ...I have a Hitchi Model# 51F500A and it looks 3D mostly the red is ghosting and I hope the convergence kit I order will help...Is there anything else that would cause this...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2010 | Hitachi 51F500 51" Rear Projection...
The right side of the TV has shadows/distorted images and colors
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 22, 2010 | Samsung PCL545R 54" Rear Projection...
No picture and the colors are distorted
  • Screen looks 3D
Jul 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Blurry pic double pic
  • Screen looks 3D
Jul 10, 2009 | Hitachi 46F510 46" Projection HDTV
Distorted picture
  • Screen looks 3D
Mar 26, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence board
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Toshiba 43H71 43" Rear Projection...
Toshiba 50h72 picture and sounds takes 20 min to warm up
  • Screen looks 3D
Sep 09, 2008 | Toshiba 50H72 50" Rear Projection...
Picture has purple and green lines and distorted
  • Screen looks 3D
Mar 17, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is [email protected] thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
