Question about Apple PowerMac G5 Dual Mac Desktop
Fans don't run
G5 dual 1.85Ghz desktop. Yesterday fan on top level (between optical drive and hard drives) began running loudly and a red light came on inside, located just above on switch. Opened it up - no dust buildup. Closed it back up, restarted. Now the red light doesn't come on and there is no loud fan noise - but apparently NONE of the fans are coming on.
  • Apple Expert
  • 481 Answers
Thank you for the complete and literate problem statement.
The red light in question will come on and the media bay fan will spin at high speed if the plastic air deflector door is not in place, OR the white sensor label on the lower right tab of the air deflector door is damaged or out of position, OR the air deflector sensor board is faulty.
You can differentiate a bad sensor label from a bad sensor board by doing the following: Remove the air deflector door. Slide a folded piece of paper through the slot in the enclosure where the right tab of the air deflector would normally be inserted. If the red LED goes out (but stays on with the door in place), the sensor label on the door is missing or damaged.
You will also want to check the sensor board cable connection on the logic board (second from right connector located directly below the hard drives).
Subsequent failure for the fans to run does not necessarily indicate a problem, as the fans are temperature-controlled and will not run until heat rises to a certain level. If the fans are not coming on even when the heat is sufficient, you may need to reset the SMU by shutting down the computer, unplugging the AC cord, waiting 15 seconds, and then replugging and restarting the computer.
Posted on May 17, 2010
Greetings, My Dell Inspiron 530S has a small
I did not look up the manual for this one. But most computers have a flashing light when the hard drive is accessed. When the drive is accessed you can hear it to. So looks to me you have a good working computer. If the sound of a hard disk is loud, you are in trouble. You should start making backups of everything if you did not do that before. If it is really just the fan, you should clean the fan and the inlet (outlet) of the airflow. most fans will accumulate dust and that will influence the warming up of the processor (your Dual-core E2160) causing the fan to run faster and faster, not capable to cool the processor enough. Often you can blow out the dust, without opening the computer, but if there stays dust in the commuter and you are not technical enough, please ask a technician to clean pup the compete airflow.
Oct 28, 2013 | Dell Inspiron 530s Desktop Computer...
My G5 Mac takes a long to start up and the the fans go wild. It's real slow. I ran a diagnostic check and everything passed. I have 80 GB left of hard drive space. Some programs are not working either.
This is a common issue for G5s. The quickest solution is to open up the computer to see how much dust there is built up inside of the case. If the case has a lot of dust by the fan vent, then it cannot properly get rid of the heat that builds up from processing. Try cleaning that out.
If the computer continues to run hot, there may be some much more major issues, including ram, processor, or hard drive. Ram and hard drive issues are relatively cheap to fix, you can purchase new ram dimms or hard drives on amazon.com or crucial.com. Processors are much harder to replace and it's likely that it would be easier to purchase a new computer, rather than a new processor.
Start with the dust issue, then go from there.
Dec 04, 2010 | Apple PowerMac G5 Dual Mac Desktop
Mac G5. Grey screen with spinning wheel. This stays liek this for an hour or so. Then get desktop but just with Hard drive folder. Can open Hard driver folder but its takes about half an hour to open then...
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Sep 27, 2010 | Apple Power Mac G5 Desktop
Loud whirring sound
Three things spin in a computer; the hard drive, the optical drive and the fan. If there are no disks in the optical drive (open it[them]), listen close, if the noise is from the front--- think hard drive, if it is in the back--- think fan. If it is in the front, back up all your data NOW. If it is in the back you need to replace the fan, (or perhaps just clean it) before the heat fries your motherboard.
May 12, 2010 | Dell Inspiron 530s Desktop Computer...
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
PowerMac G5 fan keeps running -- LOUDLY
I had the same problem... It is the logic board... You need to get it replaced. One way you could try to fix it by resetting the board there should be a little black dot behind the front two fans when you open it up. Press and hold for a few seconds... this resets the board to factory settings. The other way is replace the internal battery. and the third is to replace the logic board. $150-200
Jun 04, 2009 | Apple PowerMac G5 Dual Mac Desktop
PM G5 has red light at front before switching on
It could be your motherboard but I would first try a Apple hardware disk and run the diagnostic tests.  If you can't boot from the DVD you could try a PRAM reset.  I have seen other weird issues with the hard drive not mounting which causes the fans to run loud.  The Apple Diagnostic disk comes in your original software pack and its usually on the 2nd or 3 DVD.  Sometimes the CPU speeds get out of whack and they need to be recalbrated.
Apr 23, 2009 | Apple Power Mac G5 Desktop
Dell deminsion 3000, fans run, hard drive light on, no boot up.
Very possibly you can unhook the hard drive and cd dvd drivers then boot system see if it goes to post try and get to setup if that does not work then you system board problems or cpu problems.
Mar 16, 2009 | Dell Dimension 3000 PC Desktop
Imac g5 is so noisy
Fan sometimes get stuck on, I won't bore you with the technical details as to why or the terminal command to fix. Just do this...
Shut down. Unplug the power cord from the back of the tower. Wait 15 minutes and plug it back in. Power up, it should have reset it.
The fans are "smart", some of them are designed to run only as needed, sometimes they get a little tangled up in their own underwear.
Feb 01, 2009 | Apple iMac G5 Desktop
Apple PowerMac G5 Dual Mac Desktop Logo
235 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
