Question about Poulan "Poulan" Push Mower
Mower runs at slow speed only
After the mower starts it doesn't speed up stays at a fast idle only.
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
How do I stabilize motor speed on a Lawn-Boy mower
You need to reset air mixture jet and also idle speed.. Make sure any dirt particles in carb bowl are removed . Check for answer on U Tube videos,these can be very helpful
Oct 18, 2014 | Garden
Lawn man idles too fast
Could be a broken or worn throttle shaft,letting air in to the carb when it shouldn't !
Mar 22, 2014 | Mtd Arnold Corp RearMounted Bagger for MTD...
I have a 1986 GMC 1500 with a 5.0 and stock rochester carb. The truck will start but you must keep gassing it as it won't idle. It kicks off every time. Any suggestions on how to fix this cold natured
fast idle speed screw, works off the fast idle cam which the choke adjustment sets, it works together by linkages. This is the raised idle speed setting you need to keep a cold engine running. First you set the idle speed by the idle speed screw with engine at normal operating temperature. Then you set the linkage up so the cam is on a raised step, throttle will be held on that raised step. then you can turn the idle speed screw to get idle at about 1500-1800 rpm. Now when you start engine cold, choke will set the fast idle cam on that raised step- when engine starts and runs it should be running at your fast idle setting. That's how it supposed to work, you just have to get everything adjusted right. I hate carburetors, they never stay adjusted right. Considering their complexity and small mechanical parts, no wonder.
Dec 24, 2013 | 1986 GMC C1500
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
When compressor gets to proper pressure and starts to kick down, it stalls
when the pressure reaches its max (abt 130psi)the unloader valve
slows down the speed of the compressor and relieves backpressure
on the pump.The carb has two idle speed screws. one is high speed
to build pressure, and the other is a low spd for when the pump doesn't have
a load. this screw is on the carb between the carb and the rocker
arm cover.turn it clockwise to increase the slow spd idle until it just stays
running
Nov 20, 2011 | Dewalt D55270 gas powered air compressors
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Runs great at hwy speed pops and slow response when you stop
Sounds like a lean condition. Adjust the carburator for a richer idle mixture.
Apr 11, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Carburator settings
If you have played with them the only way is to get it going pretty well is" ....
find the idle screw - usually larger - and turn in 1/2 a turn - hopefully that will keep it running - then find the 'slow' running screw turn it in until it stops then turn out 1 and 1/2 turns. Leave the fast one alone.
Get it started then adjust idle screw so its faaster if need be.,, now slowly turn the 'slow' screw in then out say 1/2 turn and listen for it either speeding up or slowing down leave it at the point where it sounds ok and try giveing a few 1/2 speed rev ups. If it goes back and idles as before - leave it.
The fast screw... (first make sure your exhaust outlet is totally unblocked - the slightest restriction here will cause it to never run right at high speed). Start it up and then try full throttle - same thing as before try adjust the fast screw first in a little then out until it runs well at what seems the faster speed it can - then check that it accelerates well from idle to full speed. If not adjust it a little more until it does.
Once it will idle ok and return to idle and also run full speed, then you can back off the idle screw until it will idle without the chain racing arond the bar.
Bear in mind th chain wil be racing around while you adjust it so keep fingers kids and idiots well away..because you are adjusting it with that chain moving..
Nov 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
Poulan chainsaw 46cc 20" chain
You normally have 3 screws - idle speed - slow running and fast running.
First take care as if it runs faster than idle speed that chain will be whipping around also.
Second you have to determine what is the problem. Is it faulty at low speeds or high speeds ? or won't it idle.
If it has turn stops fitted to the screws you only have a small adjustments either way.
If it won't idle, try turning in the idle screw a half turn - until the chain just starts to move slowly.
If its dying at slow speeds, get is going and slow turn the slow screw out until it starts to run a bit rough then turn it back in to the point where its running smoothly.
Bad fast speed can be caused by simple things such as a blocked muffler ( insects too - I had one blocked off by a mudnest wasp) - otherwise get it running at full and adjust the fast screw as per the slow one - out till its rough then back in slowly until its smooth.
Suggest before all this tho that you get it running with the cover off the carby and then give it a good squirt of carby cleaner first - it may just clear out any 'poop' thats there.
(Have faith even tho I have a Poulan with a carb that refuses to run on anything but carby cleaner. I have pulled it apart a few times and renewed all the perishable bits buts its a real pig)
Feb 28, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan "Poulan" Push Mower Logo
687 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
