Question about LG 42LC2D 42 in. LCD HDTV
My LG LCD tv color is not right. people are
My LG LCD TV color is not right. The people are green. This problem just started. I have adjusted the tint and color and it is still bad. Thanks.
  • 304 Answers
SOURCE: whole tv has changed to be a very green tint. even
Go to the back of the tv and make sure all of the Component plugs are fully inserted and also on the source Ie: Cable Box or Sat Box,DVD Player.
Posted on Jul 18, 2009
SOURCE: LG tv color problem
i had the same problems, called LG customer service, advise to check components cable, and make sure they were all blugged in correctly, ans sure engough, the red cable was discontected ,and after correcting that, the problem was solved
Posted on Oct 01, 2007
  • 60 Answers
SOURCE: LG LCD and LG DVD remote codes
If both units are LG you don't have to program anything. Below the power button are 6 buttons labeled TV, DVD, etc. As soon as you push the DVD button the remote should work it. Remember to push the TV button again to make it work the TV.
Posted on Apr 21, 2008
phongnv
  • 56 Answers
SOURCE: My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Posted on Feb 18, 2009
ButtFuzz
  • 463 Answers
SOURCE: LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
Posted on Mar 12, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I fix the color on my tv
In the steup menu there should be a setting called "HUE" try adjusting that. If that does not work, you may have lost "green drive" circuits in your TV.
If the menu windows have the right colors, try playing a DVD or a video on it. If they look good you may have a problem with channel tuner or antenna.
Jan 15, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Too much green on tv screen
how old is the tv. did this happen suddenly or over time? also try adjusting tint that might work
Jul 23, 2009 | Televison & Video
I have a 50" LG Plasma that has lost color only with the tv
the main total assy might be the problem. it controls color, pix size and such.
Jul 09, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
LG tv color problem
Just like in Solution 3. Color was off. Looked in back and cables "appeared" to be ok. However, I disconnected the cables one by one and amazingly the color returned. So make sure your color cables are truly connected.
Sep 20, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
294 people viewed this question
Computer Repairing
Computer Repairing
