Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
Bottom dishes not cleaned well
SHX46A06 dishwasher not cleaning bottom dishes very well any longer. At first, noticed a "film" being left on dishes so we switched detergents - nothing changed. We've pulled out and cleaned trap, filter, and spray arms - still not cleaning well. Not being a dishwasher expert, the only other piece of info I can provide is that I noticed there is still some water that I can see when I pull out the fine filter. Does this mean it is not draining properly? Any other troubleshooting tips and/or ideas? The dishwasher is about 6 years old and runs once or twice a week. Thanks for any info you might provide.
  • 1 more comment
  • gary_e_johns May 14, 2010
    I am confused by this response. My understanding of this model Bosch is that it does not have a heater element; instead it has a heater assembly (aqua sensor). I've measured the water temp and it reaches approx 120 degrees. Do you believe this is still indicative of a water assembly issue? Any way to know/test (I'm not an electrician either).
    Thanks!!
  • gary_e_johns Jun 10, 2010
    I finally got around to attempting to change the heater assembly and after replacing, there is a part that I can not find where it goes. It is the "magnet plunger, top rack only". I can not find a diagram anywhere showing me where this part might go. Any ideas?
    I finally got around to attempting to replace the heating assembly. As I was putting everything back together, I noticed a part that I did not remove (fell out at some point). Searched and found that it is a "magnet, plunger, top rack only" (part # AP28023870 on Appliance Parts Pros) and I have no idea where this part goes and can find no diagram to assist. Any ideas?
    Thanks!!
  • Bosch Master
  • 43,501 Answers
  • D. Floyd Kolb
    D. Floyd Kolb May 15, 2010
    There are many different ways of dishwashers heating the water and my point was that you have a problem with the water not getting hot enough,,,you have proven that by stating that the water was 120... it should be at least 140 for good cleaning and proper santitizing of your dishes...
    Yes, that heating assemply is probably not working properly...
    Do a search online for repair parts for your dishwasher and then order the needed part.
    How to Buy Appliance Parts Online
    http://www.fixya.com/support/r3907570-bu...
    Have a great day!!
    heatman101
Not cleaning properly leaving film on glasses
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 17, 2011 | Whirlpool Dishwashers
The dishwasher doesn't seem to be cleaning very well any more. The glasses are always dirty and the dishes just don't seem to be clean like they used to be. Does the dishwasher need some maintenance? ...
Check the following:
- The Salt Container - Found at the bottom of the Dishwasher. (If required, replenish salt)
- The spray arms (They usually get clogged at the small holes where the water should spray out of)
- Us less heat (High heat can leave white visible stains on glass)
Hope this helps :-) - J.Q
Feb 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Not cleaning well
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Maytag Dishwasher
I have a model GU2300XTVQ Lately we have fine brown residue on the bottom and door of the unit whenit finishes washing. The dishes seem clean. Is there a filter or something we need to clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 07, 2011 | Whirlpool GU2300XTVQ Builtin Dishwasher
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes and glasses not getting clean. Visaul inspection; it lloks fine. Removed filter and bottom perforated filter panle and cleaned off mineral-like residue. ran test program: result flashing lights for...
heatman101
Jul 03, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My dishwasher is no longer cleaning properly. A
Clean out the area where food gets caught and consider using different dishwashing tablets - especially the Calgon ones which clean out the drains of teh machine whilst cleaning the dishes.
Alternitivly you should call in a plumber to clean the pipes (Or purchase the equiptment to do it yourself, there are often all-in-one cleaners that'll flush out the pipes)
Dec 24, 2009 | KitchenAid Dishwashers
Dishes are not cleaning and a filmis left on the
Use FINISH detergent with built in rinse agent.
Water should be at least 140 degrees.
is there a LOT of water in the bottom of the machine after cycle?
Jun 27, 2009 | Dishwashers
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
221 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
