Question about Delta Enterprise Snoopy Deluxe Crib
How to remove canopy from bassinet so cover can be
How to remove canopy from bassinet, so cover can be washed
Removing fabric for washing
Hi! Were you able to figure it out? I am having the same issue and it is driving me nuts! Lol. I dont get hoe the instructions dont provide details for fabric removal! Please let me know if you were able to get it off. I got mine second hand and it is filthy. :(
Feb 14, 2012 | Kidsline Premium Bebe Fina BF9111 Crib
How do I remove the canopy to wash the frabric on my bassinet?
Many bassinets have rivets that dont allow you to remove the fabric.
We draw water in the washer and add soap then drop one end in
and work it around until it is in the washer. Use gentle cycle and
cross your fingers that no damage is done. I have washed many of them
and never destroyed one. Good luck
Feb 23, 2011 | Baby Gear
How do you take off the bassinet cover for the top part that is like a canopy?
If this is for a bassinet here is the answer I posted for another person. If not, just let us know.
We will see what we can do for you.
Feb 23, 2011 | Delta Luv Angelina
How to take off the cover on the canopy for the light vibes mobile cuddle 'n care bassinett
If you are going to wash it, I think it is riveted on. No way to remove it from the support. We just wash ours complete in the washer with very little else. It will fit. Just let it air dry.
May 09, 2010 | Kolcraft Ultra Light Vibes 18275 Crib
Bedding
I got this bassinet 2nd hand. I can tell you that I did wash the whole set. You have to take the screws out at either end to remove the cover (one screw is behind the batteries in the music box). I removed the plastic parts (the slits are closed with velcro for the flat plastic panels so the plastic simply slides out). The hoops were a little more difficult but since it is an overlap closing and the hoops are flexible, you can remove them. Simply wash in cold water and hang to dry. When its dry, you can put the plastic slides and hoops back in the same way you took them out. Came out fine.
Jun 19, 2008 | Eddie Bauer Musical Rocking Bassinet...
Washing the bedding
no. wash the canopy manually.. soak it in soap and water then rinse.
Jun 18, 2008 | Eddie Bauer Musical Rocking Bassinet...
How do you take the covers off
there are two screws on the sides, you might want to unscrew them, after you do so the thin bar should snap off if u give it a little tug..then you can remove the canopy and the rest of the covers..make sure you remember how it looks before you take everything off..because it could be trick putting it back together, thats my problem now i cant remember how the canopy gpoes back on...?
May 29, 2008 | Delta Enterprise Snoopy Deluxe Crib
I have a 3112doh Winnie the Pooh bassinet
I could not get the fabric off my canopy either. I found it slide nicely into my washer (top loader with agitator) even with metal insert. I washed on delicate and it came out great, with no damage to canopy.
May 29, 2008 | Simplicity for Children 4-in-1 Convertible...
CANOPY
return it to the store it was recalled Aug 31, 2008 for strangulation hazard as two babies died from this thing
Mar 10, 2008 | Simplicity for Children 4-in-1 Convertible...
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
Delta Enterprise Snoopy Deluxe Crib Logo
1,272 people viewed this question
Top Delta Enterprise Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Delta Enterprise Baby Gear Expert? Answer questions, earn points and help others
