Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
What is a ZNR V10431U, and where can i get one or a drop in replacement.
75hp Mercury 4 stroke boat motor doesn't charge battery. Diagnostics say check battery connections and turn off switches. Battery charge dropped 3 v in 30 minutes.
Does the battery voltage drops below 11.8v with battery disconnected?
If yes: replace the battery
If NO: disconnect the charge regultor in the engine. See then if the voltage still drops.
If it doesn't drop anymore: replace the regulator!
Aug 14, 2017 | Mercury Boating
I replaced my starter and now the car doesn't even make a clicking sound and still won't start
What make , model an year vehicle ? Didn't start before you replaced the starter an still won't start ? Did you test it before replacing it ? Voltage drop testing the starter electrical circuit is how to find the problem !
Starter Voltage Drop
How to voltage drop test starter motor circuit
Apr 20, 2017 | Cars & Trucks
V3xx drop call
Test your sim card in the Nokia phone and if the cals still drop then you will need to replace your sim card. If you dont drop calls in the Nokia phone then you will need to have the device replaced. AT&T Customer service number is 800-331-0500 for replacement options.
Mar 09, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
1999 Cadillac Deville - How to replace fuel pump? Fuse is OK and fuel pump does not run. Is fuel pump accessible through trunk or must you drop tank? Thanks in advance for your help.
Unfortunetly Cadillac does not have an access panel for fuel pump access until the newer years. You will need to drop the tank. Also, don't let the tank come slamming to the ground, make sure you take it slow so you dont dammage the lines to the sending unit.
Good Luck!
Dec 15, 2009 | Cadillac DeVille Cars & Trucks
Ihave 110 volt makita dc18rc battery charger, component VDR101 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
I had the exact same problem. I ordered the ZNR V10 241U part from Dija Key. They are around 36 cents if you buy 10 of them. I cut the old one out and soldered the new one in. I changed the fuse over to an automotive one so the fuse is easier to obtain. I plugged it in and charger works fine.
What happens is a voltage spike either low or high gets recieved by the charger. The fuse appears to be slow blowing and does not stop the spike in time. The spike is stopped by the varactor surge supresser. In doing so, it saves the circuit board so all you have to replace is the fuse and the surge surprsser.
Nov 26, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Fuse blows-up in my microwave
First you check AC main line ZNR blast,then check diode short
Jul 08, 2009 | Kenmore 62702 Microwave Oven
Need to install fuel pump in 1991 pontiac firebird
Sorry. Got to drop the tank. Just break the gas tank bolts and replace them with new ones. If the straps are badly rusted, replace them, too. Look for tank leaks on the top of the tank. Replace the sock on the fuel pump.
Jun 02, 2009 | 1991 Pontiac Firebird
Need to replace drop in range
All you have to do is make sure you have the same drop in top as the hole cut for it. Measure the opening, and then measeure flange to flange on the one you have. The flange will be 1/2" or so bigger than the hole; that's what holds it in.
They are ususall 30 or 36" wide. It doesn't have to be a Kenmore, just match the color to everything else.
Need to know how to disconnect it?
Dan
May 11, 2009 | Kenmore Kitchen Ranges
Drop hardisc will it spoilt?
Dropping hard drives is never recommended, though most hard drives are designed to withstand a hefty impact of up to about 200G, which is equivalent to a drop from about 1inch onto a hard surface.  If it is an empty drive, I would personally recommend replacing the drive with a new one.  If it is an old drive, you should be able to start up the drive and retrieve some of your data, but again I would recommend replacing it ASAP.
Oct 23, 2007 | Computers & Internet
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
374 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
