Question about Garden
Cub Cadet 2160 charging problem
The Low Volt light comes on sometimes, but only when PTO is engaged. It has a new battery, which I charged before installing. All wiring checks out, stator winding(s) are not open, and the diodes in the 'alternator' test OK.
wadembly
  • 448 Answers
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
wireguy212
  • 1627 Answers
SOURCE: When I engage the PTO clutch, the amp light comes
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Posted on Nov 07, 2009
My cub cadet pto will kick off when you go faster, it will only run when you are just barely moving
If you are referring to an electric PTO here is the way they work. They need good current from the battery to stay engaged because they are a electric clutch and if the charging system is not supplying the right voltage to keep the battery at a good state you would have a charging problem. Another could be the clutch may be worn enough to cause the problem and that would be the most likely cause if you have a known good or new battery. Hope this will help you.
May 30, 2017 | Cub Cadet Garden
PTO wont engage unless battery is charged up
Dale, it is normal for the PTO not to engage when voltage is low. Have battery and charging system diagnosed and repaired.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Charging System Battery Alternator Test Briggs FAQ
CHARGING SYSTEM MAINTENANCE
LAWN MOWER TRACTOR ZTR HOW TO TEST SMALL ENGINE VOLTAGE REGULATOR...
May 25, 2016 | Cub Cadet Garden
Everything works fine until I engage the PTO for the mower deck. The battery discharge light comes on and eventually the battery goes dead.
The PTO clutch is an electro magnet. There is probably a dead short within the clutch body. Replace the Clutch.
Aug 26, 2015 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
Nov 07, 2009 | Garden
Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Jun 30, 2009 | Oregon Scientific Electric PTO Clutch for...
Cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
