Question about Zanussi ZWF1440 Front Load Washer
Black mould the mould is in the rubber door seal of the machine, and very hard to remove, have tried various detergents....what causes it ????? The machine is a Zanussi
    Top Expert:
  • Zanussi Master
  • 76,846 Answers
This is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
Posted on May 13, 2010
Mold door seal
If you want the door seal replaced any local domestic engineer will be able to do this. The mould is caused by excess detergent, constant washing at low temperatures, keeping the door closed when the machine is not in use. If you want to stop the mould reappearing once the seal has been replaced you need to carry out regular service washes (boil wash with a descaler/sanitiser). Use the correct amount of detergent for the amount of washing to be done and the hardness of the water in your area. Give the door seal a quick wipe after you use it and try and keep the door slighlty ajar when not in use.
Oct 18, 2013 | Siemens WFXD5200UC Front Load Washer
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
How to remove black mould from rubber door seal
the best thing to do is replace the rubber boot.
Mar 19, 2011 | Washing Machines
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
Mold inside the rubber seal as well as inside the glass in the door. Clothes are not fresh. I have to keep the door open due to the smell.
Bosch Nexxt Premium WFMC6400UC Front Load Washer mould on rubber seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Black mould round door seal
There are several reasons for this to happen.
the primary one is the fact that you are doing a lot of low temp washes, and this causes a build up of grease and dirt around the door seal, the mould you refer to is actually bacteria.
You must do a high temp wash at least once every 6 to 8 weeks, put powder and or detergent in as usual, but no washing, and let it do a full cycle.
This is called a maintenance wash and helps prevent what has happened to your m/c.
Thoroughly clean the door seal with a scouring pad or stainless steel wool, you will not harm the seal,
You will probably find the seal will be stained, but as long as you get all the mould etc off, it will be o/k.
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit Washing Machines
Mould on Rubber Seal and Musty Smell
bleaching hte rubber will help, you need to check your detergent, you MUST be using an HE detergent, specifically designed for frontloading machines, leaving the door open as well between usage, and running more than just cold washes, HOT water definalty helps.as far as efficincy this machine uses abouit 1/3 of hte water the top loaders do. 13-16 gal, versus 45-50 gal. so an extra rinse is not going to amount ot much. there are also products such as www.AFFRESH tabs, or even "dishwasher magic" has been known to reduced the smells/odors in oyour washer
Dec 22, 2008 | Washing Machines
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
651 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
