Question about RCA TH1101 MP3 Player
My mp3 player is corrupted
How do i fix it or reset it
  • 2 more comments
  • Anonymous May 01, 2008
    Mine is doing the same thing only it won't even let me open the file tab on my computer or right click it.
  • C-O2011 May 04, 2008
    I think i messed my mp3 player up i didnt close tha file when i took it out and now i read tha solution and it tried it.......it didnt work plus i dont kno how to format it.....i need more instruction on that.
    Also it makes my computer go slow what should i do??
  • soniajc May 07, 2008
    My MP3 player says there are no files in it. One day, i was going to change the music, and when I plugged it into my computer, the screen told me all fiels were deleted. Now, I can't even get the thing to download any music or anything. I also lost or misplaced the CD that came with it. i was thinking i could reload it, but i can't find the software. Where could i get another copy without buying another one?
  • biguastin_22 May 22, 2008
    ya i deleted like 2 songs then i unpluged it to go some where and when i came back it said that all my files where lost and 214 of my songs where deleted
  • 3 Answers
Format ur removable disk.....if it freezes wait patiently....it will unfreeze by itself but u will lose all ur files......
Posted on Apr 04, 2008
SOURCE:
How to fix file system erroron mp3 player
Try doing a soft reset.
Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
Hold until the player shuts down.
Power on the player again by using the Power on/off key.
Your songs and data will not be lost or corrupted by a soft reset.
If soft reset does not work, then you may have to use the Device Manager to recover your player.
How to do it is described on the manufacturer's web site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045%2F37&dct=FAQ&faqview=1&new_tmpl=1&refdisplay=PI_C35_SA60XX_002&refnr=0063493&scy=US&slg=AEN
I hope your player will work fine again.
Thanks.
gylacz
Aug 16, 2011 | Philips GOGEAR SA6045 MP3 Player
Corrupted data
hi,
If there is corrupted data in your Mp3 player, please reformat your player your factory settings(it depends upon the manufacturer, mostly use the reverse side of the needle to press in the pinhole that is available somewhere in your player). This action deletes all the files in your player and all the settings are reset. Your player will be now like a new one. You can upload music again and use it as normal one. Thanks for choosing fix-ya!. Please rate my solution as helpful.
Apr 02, 2010 | Audio Players & Recorders
Startup says file system error
Reset it. Its not good getting that message. It probably means hard drive is corrupted!
Jul 06, 2009 | Philips GoGear HDD1830 MP3 Player
Won't go to song screen
Your DB is corrupt. Download the newest version of the Philips Device Manager for your model # at www.usasupport.philips.com, and then click the "Update" function once it is installed. The update wil lresolve your issue.
-Tha Mp3 Doctor
Feb 06, 2009 | Philips SA5125/37 MP3 Player
Corrupted
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be gooOd to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips SA5125/37 MP3 Player
My sansa E250 has been corrupted!!
My MP3 freezes up when I turn it on
How can I fix this problem?
Aug 03, 2008 | SanDisk Sansa e250 MP3 Player
I need help!!!!!!
it may just be that certain song is corrupt and cant play you can try downloading the song again, but if it still does it the mp3 is probably faulty
May 10, 2008 | SanDisk Sansa E280 MP3 Player
How do you fix it
Press and hold [Play / Pause] & [VOL+] to reset the player if it freezes.
Freezing may be caused by corrupt firmware or a DRM protected track.
Mar 28, 2008 | Philips GoGear HDD084 MP3 Player
Wont charge and memory corrupt even after i reset tons of times
Plug your MP3 Player into your Pc and Format The removable Drive Then Re-load your music onto it if that doesn't work it'll have to be a hardware problem my only other suggestion is get out your Guarantee and send it in
Jan 15, 2008 | Philips SA5125/37 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
RCA TH1101 MP3 Player Logo
89 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
