Question about Dryers
Mod# 110.64642400 not heating up. everything else works. only 3 yrs old
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryermod# 110.64642400 not heating up. everything else - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
dryer is electric2_bing.gifDryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 15, 2010
Whirlpool freezer lite not working. Bulb is good. Mod gx5fhtxvy. 3 yrs old.
You might need to deice the freezer or check the fan to see if it needs to be replaced.
Jul 11, 2017 | Miscellaneous
Tip
I'm wondering if my Jenn-Air Model JER8885QCS needs a new probe or not. It's a...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Mar 31, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Not heating only 2 yrs old everything else works in it
unless u know what ure doing don't go near the inside they hold up to 10.000 volts via a capasator
Dec 05, 2014 | Hamilton Beach Microwave Ovens
I have a whirlpool dryer (wed5540sq) and will not heat. it is only about 2 yrs old. I have put a brand new plug on and it does nothing. if i put the old plug back on, it will turn but not heat
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 06, 2010 | Whirlpool Dryers
Food in the frig has been freezing even when the freezer is set to 3 and the frig is set to2 (mod. pss25mgmb) the unit is only about 6 yrs old
could be drain holes blocked or both temp sensors gone at same time ?? hardly.also have you tried a full manual defrost (no hot water) sometimes works for me
Feb 07, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Will not heat at all
Could be the "board". Well known for failure. Get the part number from the board & search eBay for NEW board.Instructions probably on youtube
Mar 05, 2018 | Electrolux Over-the-Range Microwave
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Dryers Logo
96 people viewed this question
Top Dryers Experts
