Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Please assist. i have not use my cleaner in awhile not sure if the clean water goes in the top or bottom.
  • 438 Answers
The clean water goes in the upper tank mixed with shampoo, and after the water is extracted from the carpet, it will go into the lower tank. Clean water top tank, dirty water lower tank.
Hope this helped you!
Chris Jones
GoVacuum.com
Posted on May 13, 2010
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do you put the soap cleaner, does this go
The cleaning solution goes in the top tank. Fill top tank with hot water first, then add the cleaning solution. That way it doesn't foam up. The tank lid is also a cup to measure how much solution you put in. Usually fill to top line. Make sure when you put tank on machine it snaps in place. if you have a manual, refer to it for instructions if you need to.
Hope this helps.
Sep 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have the 8920 bissell proheat steam cleaner. i
You must have a suction problem. Try checking the lint filter, which is located in the top clear plastic section (the section that goes on top of the bladder section - it has the dial to switch from floor to tool use). There is a small plastic lint filter (about 1 inch square) with a little door on it (on my model it is red plastic) . Open the door, remove the hair or whatever is clogging it and hopefully your problem will be solved. And the lady you got it from is correct, the dirty water is stored in the area that surrounds the clean water bladder.
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I don't know where to put the water?
The clean water goes on top. You want to check your bottom tank and make sure the lid is not lose.
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I need to clean the main filter
Be sure you wash the filter that is above the canister compartment. It has an orange lever to release it. I over looked this the first year I had the vaccume, dust was really caked in there. I also just wash out the inside of the canister with water once in awhile.
Mar 18, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
My carpet cleaner will not pick up water.
Check to make sure that the recovery tank lid is fastened down all of the way around. Also if the foam filter on the bottom of the tank lid, make sure there is at least a 1/4 inch gap from the top of the lid. The wire screen filter is plugged, from the bottom, it has a red frame, pull it out far enough to clean it. These are the causes for non-suction.
Jul 19, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Removing the hood to clean the cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=498921
Posted by bfy1952 on Apr 08, 2008
How do I remove the cleaner hood the clear see thru plastic to clean under the hood?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. There may be 2 ways to remove the top cover. There are two screws located on the bottom and there are 2 ways that might work. The clear tube on Hoover’s sometimes will swivel and that is the way to bet the clear tube unclogged, or once you remove the 2 – 4 screws on the bottom the top should lift right off, and then you can serviced your vacuum cleaner. If you have questions you can always contact your local vacuum cleaner dealer in your area or call tech support @ the Hoover @ the factory and ask for tech support.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Hoover F5881-900 Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
104 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
