Question about Dell Vostro 1500 Notebook
Retainer clip on back of tab key needs replacement
    Sergeant:
  • 310 Answers
They just clip together then push the key on, you should get a replacement in ebay.
Posted on May 13, 2010
How to remove headlight housing 2001 FLSTC
To remove the headlamp housing assembly disconnect the wiring harness and then remove the bolt underneath the housing and ligt the housing off the mount.
To change headlamp bulbs:
2001 FXSTD, FXSTS and FLSTS Models
Remove the trim ring screw and then the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
unhook them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb, replace the bulb and re-assemble all.
2001 FXST and FXSTB Models
Loosen the trim ring screw and remove the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
FLSTC and FLSTF Models
Except for HDI motorcycles which have a Halogen bulb similar to FXST the FLSTC and FLSTF motorcycles have a sealed beam type headlamp. HDI headlamps also contain a position lamp bulb that is found under the headlamp assembly's rubber boot.
Remove the trim ring screw and then the trim ring, being careful not to bend the two tabs that hold the
top of the trim ring in place, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
May 17, 2014 | 2000 Harley Davidson FLSTC Heritage...
I want to change the filter on my broan 42000-k range hood. filter number 97006931, never done it before. help?
Look at this exploded view:
http://www.appliancefactoryparts.com/hvac/broan/423601.html
Part number 11 is a retainer clip.
Here is the instruction manual:
http://www.appliancefactoryparts.com/content/pdfs/137548-2.pdf
Page five, illustration 13, shows that the retainer clip is turned 90 degrees to release the filter, turned back to retain the replacement.
Here's a cut and paste of the manual:
"FILTERS
40000, 42000 & 42000D Hoods Only:
Remove aluminum filter by turning filter retainer to
one side. (FIG. 13) Filter should be washed once a
month in a hot detergent solution. Aluminum filters
are dishwasher safe. When installing filter, make sure
that filter slides under retaining tabs on back of fan
housing. Turn filter retainer so that arrows on retainer
point toward front and back of hood."
Sep 21, 2013 | Broan-NuTone Allure II QS230SS Kitchen...
Lid switch needs to be replaced
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 23, 2011 | Kenmore Washing Machines
How can I replace the pump belt of a washing machine Sears Kenmore model #110.82671710 stock #26717
The Kenmore top load washing with the given model number 110.82671710 is a direct-drive type and doesn't have a pump belt. The pump is directly coupled to the rear spline of the motor.
The cabinet needs to be removed if access to the drain pump and replacement is necessary. Remove the screws attaching the bottom front corner of the console to the top of the cabinet then pull forward and up on the console and lay it back on the hinges.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Detach the hoses from the drain pump and attach it to the new one then install it back into the rear spline of the motor and secure it with the retaining clips. Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Dec 23, 2010 | Kenmore Washing Machines
How to remove my key lock 2000dodge caravan
Ignition Lock Cylinder - Removal & Installation CAUTION The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the air bag or SIR wiring. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
  1. Disconnect and isolate the negative battery cable from the battery.
  2. In order to disarm the air bag system, allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures.
  3. Remove the screws that secure the parking brake release handle to the instrument panel.
  4. Remove the screws that secure the bottom of the lower steering column cover to the instrument panel.
  5. Disengage the retaining clip that holds the right side of the lower steering column cover to the instrument panel.
  6. Remove the lower steering column cover from the vehicle.
  7. Remove the mounting screws that hold the upper and lower steering column shrouds and remove the lower steering column shroud.
  8. Install the ignition key and turn the key cylinder to the RUN position. This is important because it will not only aid in removal of the ignition lock, but will also place the socket (in the lock cylinder housing) in proper alignment for the installation of the replacement ignition lock.
  9. Press in the lock cylinder retaining tab and remove the key cylinder (ignition lock).
    Fig. Depress the retaining tab to remove the key cylinder
To install:
  1. Install the ignition key into the replacement ignition lock key cylinder. Turn the key to the RUN position. Depress the ignition lock key cylinder retaining tab.
  2. Align the shaft at the end of the ignition lock cylinder with the socket in the end of the ignition lock cylinder housing.
  3. Align the ignition lock cylinder with the grooves in the lock cylinder housing. Push the ignition lock cylinder into the housing until the retaining tab sticks through the opening in the lock cylinder housing.
  4. Turn the ignition key to the OFF position and remove the key.
  5. Install the lower steering column shroud and install the mounting screws.
  6. Place the lower steering column cover into correct position on the lower instrument panel and engage the clip that secures the right side of the cover to the instrument panel.
  7. Install the lower steering column mounting screws.
  8. Install the mounting screws that hold the parking brake release handle to the instrument panel.
  9. Reconnect the negative battery cable.
Hope helps (remember rated and comment this).
Aug 11, 2010 | 2000 Dodge Caravan
My 3 y/o knocked keys off the laptop keyboard. How do I reattach? Only the key face cameoff the plastic clip is still in place.
If the clips are still in place then place the key over the clip align the key cap so it is in line with the other keys and press down on the key cap until it clicks onto the clips.
Jun 23, 2010 | Acer Aspire 7720 Notebook
How to replace keys
the screws that hold the keyboard is usually under long plastic cover on the top the keyboard..
Feb 14, 2010 | Toshiba Satellite A135-S4527 Notebook
One key fell off
You should be able to place it on the retainer and press it on, you may need to move it around a bit. If it just flat won't snap back on, check the retainer to make sure that the pins that fit into the clips on the back of the key aren't bent or broken, and check the clips on the key to see if the sides are bent or broken. If the pins or sides of the clips are bent, take a small flathead screwdriver and straighten them. If they're broken it will need to be replaced.
Aug 09, 2008 | Toshiba Satellite A85-S107 Notebook
Re-assembly after belt replacement
The small red clip has a tab on it to hold in place while putting back on. put the screw in the hole in clip and use tab to guide into place. if there is no tab, then you need to obtain a new set of clips, very inexpensive. the laege red clip is easy to put on since it goes into a groove and can't go on backward.
Jun 12, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Vostro 1500 Notebook Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
