Question about Uniden Cordless Phone
GE 5.8 GHz Digital Cordless Phone Mdeol # 25830GE3-M
When I have a voice mail message I haven't listened to yet, the Charge/In Use Red Indicator light does NOT blink as it should according to the user's manual. It used to blink, then one day, it wasn't blinking when it should have been blinking and hasn't since.
Please advise!
SOURCE: uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Posted on May 29, 2008
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Posted on Oct 03, 2008
SOURCE: GE cordless phone no longer will make or accept calls
try new battery. that happened to me this weekend. i put the battery fro the second handset i dont use in it and everythings fine.
Posted on Jan 19, 2009
jgcalifornia
  • 160 Answers
SOURCE: our ge cordless phones model 25830ge3-a is out of
Cordless Phone Extender
Posted on Sep 02, 2009
SOURCE: base keeps blinking, and phone says new voice
try unplugging the base to reset it. That voicemail signal is set on or off by your phone service provider. Check with them to see if a: you have v-mail or b: they can reset it
Posted on Sep 13, 2009
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
Indicator light won't stop flashing
I have a Uniden 5.8 GHz and the message indicator light will not stop flashing. The phone screen says I have a voice mail but I don't. Does anyone know to fix it?
Feb 04, 2010 | Uniden 5.8GHz Cordless Phone
All phones are flashing red
This is a "Voice Message Waiting Indicator" and it means that you have a new voice mail from your telephone service provider, or a new message on your answering machine. A lot of people do not even realize they have voice mail from their service provider because all the phone companies bundle services now. If you do not have a message on either you can reset the indicator by following the instructions in the manual
Jun 30, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
New Voice mail flashing on phone but no new messages
Have someone call you and leave you a message. then listen to the message and that might reset it.If that dont work call the manufacturer and they will walk you through it and should not charge you for it.
Jan 04, 2009 | GE 25865 Cordless Phone
Voice mail message waiting light does not light
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
New Voice Mail flashing light
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
May 10, 2008 | Uniden Cordless Phone
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
"NEW VOICE MAIL" is stuck on screen
what you do is call your own phone number it will tell you to set up a voicemail account and make a 4 digit pin ....once that is made you can listen to the prompts to listen to your voicemail and erase the messege and the phone will get back to its normal self hope this helps
Feb 17, 2008 | GE 25932 Cordless Phone
"new voice mail" display
call your phone service and have them disconnect the voice mail and if they cant just remove that have them set there rings at like 9 since most phones only have up to 5 rings for the machine to answer.you will have to use there voice mail service to hear your message and then delete it but should be good after that. i have comcast and they said it would take 3 days to deactivate voice mail but told me how to get there so i can get rid of that flashing light, hope this helps you
Oct 28, 2007 | GE 25942GE2 Cordless Phone System
Voice mail
Do your Dial tone sound different. Your phone listens to the dial tone. if you have a new voice mail your dial tone changes.and your phone does the flashy thing accordingly. Contact your phone company.
Aug 18, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Uniden Cordless Phone Logo
285 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
