Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
LaCie firewire 400 cannot be read by computer apple Mac g5
Hello all and i hope someone could help about my problem i have a lacie 300gb until recently it was working without any problems last time i switched it off i turned it off through the back button in the device instead of dragging the icon to the trash bin then turn it off, when i try to use the device again, it did not work, i have a apple mac g5 without the intel processor, my lacie only have a year, and i could see that it appears on the system profile and i disk utility when i did verify the disk it comes with the following error:
Verify and Repair disk “LACIE”
** /dev/disk1s1
** Phase 1 - Read FAT
** Phase 2 - Check Cluster Chains
** Phase 3 - Checking Directories
Unable to read directory (Input/output error)
Error: The underlying task reported failure on exit
1 non HFS volume checked
1 volume could not be repaired because of an error
dont know what else to do and i hope i havent lost all the info within the Lacie, so any help would be welcome, and thanks for it.
    Guru:
  • 206 Answers
Whenever there is an HFS Volume could not be repaired issue, that means that your hard drive's existing volume has been damaged and may not be retrievable. In most cases like this, you would be advised to perform an Erase and Install to correct the damaged directory on your portable HD. However, as I understand that is not what you want to do, you may want to research Mac Utility software like these titles below:
Disc Warrior 4.1
font.f1 {font: 12.0px Helvetica}
(for Macs from Alsoft)
Tech Tools Pro 5.0 (for Macs from Micromat)
Drive Genius 2 - Mac (for Macs from Prosoft Engineering)
These are three of the better hard drive diagnostics, repair and directory rebuilding software on the market for Mac Users. I have used them a number of times as a professional onsite Certified Mac technician and they have helped me to help the customers I assisted many times over.
These Mac Utility software all have a price point of under $100.00 and when you are able to experience just how well they work, you find it is worth the investment.
an HFS volume error is repairable with the right software and these utilities are your best option aside from outright erasing and installing your Lacie HD.
Posted on Jan 26, 2010
  • 34 Answers
Your drive is formatted as FAT - which is more a WIndows format than a Mac one (HFS+). You might need a specialist repair tool like Tech Tool Pro to rebuild the directory.
Posted on Aug 28, 2009
  • 600 Answers
You need a 3rd party disc utility to repair the directories, your info is safe but the map is corrupted so it cant be found, I use a prosoft product and it allways works
Posted on Aug 13, 2009
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
Arghhhh!!! Problems with my Lacie Brick crashing my Mac
o you use this software called
MacDrive - 7.0.10If yes dump it immediately...This problem was occuring on my friend's PC too..due to that useless software!
Oct 11, 2007 | Computers & Internet
My MAC G5 no longer recognizes my harddrive. Blue light flashes, light clicking noise.
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 29, 2010 | LaCie (301146U) 320 GB FireWire 400...
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 1000gb external drive
I own a Lacie product that does the same thing. It uses firewire but it was clicking a few times and then would not display as a drive. I moved to another computer (with a different firewire card) and it worked. I decided that the firewire card was the issue at the time, but the card still read other devices like digital video camera. I know you are using the USB 2.0 cable. Can you try your drive on a different computer? That would narrow the possible solutions down.
Jun 26, 2007 | LaCie (300951U) 500 GB Hard Drive
Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
561 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
