Question about Garden
How do i adjust cutting belt on a westwood T1600 as it keeps coming off when cutting grass
  • 246 Answers
SOURCE: how to adjust belt tension 42" raftsman lawn tractor cutting deck
Hello:
Depending on the Model of this Unit it May have an Adjuster or the Belt May be Tensioned by a Spring and Idler Pulley.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: 42" mtd yardmachine belt keeps coming off
twords the rear of the deck there are two bars with pins that hold the deck.they should have 3 or 4 holes where you can adjust the rear of the deck.check to see if there set to the middle somewhere,if so you can disconnect the 2 pins and try going up 1 hole iif that didn't work try down 1 from original point.
Posted on Jun 06, 2009
  • 7 Answers
SOURCE: Hi, Mum has a wtd wanrite mtt model 548/12hp mower ride
Hi this sounds like there is a spot of dirt in tne fuel system
you will need to dismantle the carburettor which is quite straight forward (be careful not to lose any screws or gaskets
guive the carburettor a good rinse in neat petrol/gasoline and blow out any debris that may be there.
re assemble the carburettor and prime with fuel and you should then be ok.
One other thought if you have found that the motor runs fine without being on the grass (eg it doesn't cut out after a minute or two) then it could be that you have the cutting blades set too low for your first cut. To raise the blade adjust the height of the wheels. Always start cutting with a high setting especially if the lawn hasn't been cut for a while.
hope this helps
W
Posted on Jun 20, 2009
  • 8404 Answers
SOURCE: If the belt comes off a riding lawn mower...will
Probably not.
I would expect to find two belts on a riding mower; one to drive the riding lawn mower (lets call this the DRIVER) and one to drive the actual mower part (lets call this the MOWER).
To answer your question one way, if the driver belt is off, it will still cut grass, but you cant move the mower. If the mower belt is off, it will move but not cut the grass.
If your belt is broken, take it to an automotive parts store or garden equipment place for replacement. You might also support a FixYa.com advertiser.
I hope this answers your question. Thanks for posting at FixYa.com and please vote.
thanks
a
Posted on Nov 14, 2009
Testimonial: "Thank You So Much For The info on lawn mower belts Now I know the guy I hired was not cutting the grass at all...Just had some fun riding around"
  • 857 Answers
SOURCE: Westwood transmission belt 1688,2281110A how do
Try these steps:
There are usually two belts; one for the deck and the other is called the drive belt. It sounds like the drive belt failed.
Both the drive belt and the deck belt run off the engine by way of a double pulley on the end of the engine shaft. I'm hoping that you're nodding your head right now. That takes care of pulley #1 for the drive belt.
The second pulley is the idler pulley. Its job is to ensure that proper tension is maintained on the drive belt so it does not slip. If your tractor has a manually controlled release, the idler pulley will pivot when the clutch/brake pedal is depressed and the tension will decrease to a level that allows the tractor to sit still. If your tractor has an electronic clutch, the idler pulley will not move when the pedal is depressed and serves only to maintain proper belt tension.
The third pulley is usually on top of the rear axle and supplies power (torque and speed) to the input shaft of the gearbox. If you have a hydrostatic transmission, the rear pulley drives a pump. What's the difference? A hydrostatic transmission doesn't have a gearshift. It only goes forward or reverse depending on how the pedal is depressed.
If you have the mechanical (idler) style, make sure that the clutch Paddy is depressed fully and locked before attempting to replace the belt. Loosen any belt retaining devices (bars or covers) and slide the new belt on.
I haven't had to replace the belt on my hydrostatic tractor (with electronic clutch) yet, but I'm sure that it has an idler pulley too. Most belt-driven systems do. Good luck!
Posted on Aug 22, 2010
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Got a t1600 westwood ride on mower and when I turn the key it wont start and there no lights on the dash at all could anyone help please
how old is this unit
name t1600 were made over a few years
check off this list
flat battery
loose terminals
faulty wiring at ignition or starter
Mar 05, 2017 | Garden
I get a click when starting my My Westwood t1600 42h tractor lawnmower I have recharged the battery and still the same any ideas
Battery is not taking charge - what you hear is the start solenoid engaging. Replace battery.
Oct 09, 2016 | Garden
Westwood T1600 Smoking and burning smell?
Burning rubber smell indicates that you must have a worn out belt that is starting to slip making the burnt rubber smell. I think you need to replace at least one belt, maybe more upon inspection of the rest.
Jun 21, 2014 | Garden
Westwood t1600
It appears you need to post in another location. Most hard drives do not have gear boxes.
Jun 15, 2014 | Computers & Internet
Why does my Westwood T1600 keeps cutting out
I would adjust valves to start.
Apr 30, 2014 | Garden
Riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Sep 23, 2009 | Garden
hope this helps
W
Jun 12, 2009 | Briggs & Stratton Garden
Garden Logo
418 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
