Question about Dehumidifiers
I need to switch it from hose drain to internal bucket drain
    President:
  • 2,468 Answers
Remove the hose and insert the water bucket and it will automatically switch over and when bucket is full it will shut off till the bucket is emptied again,please rate this on fixya,thank you
Posted on May 13, 2010
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
How do I get water to come out the hose instead of the bucket?
a special adaptor is required from the mfg to allow this it bypasses the internal passageway to internal bucket and has a hose connection to what a normal garden style hose can be connected and directed over to a floor drain or pump pit
this method still requires normal maintence and cleaning thought as it can stop up too
Oct 16, 2014 | Dehumidifiers
Hose hooked up but bucket fills anyway. Hose is attached to internal nozzle. Is that right?
The problem you're having is generally cause by the drain hose or drain hose connection being clogged. When that happens water is diverted to the bucket. To solve this problem do the following:
First disconnect the drain hose for clogs to check for a clog.. Also, the hose should be no longer than 5 feet. If the hose is clear, the clog is in the hose connection or tubing.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor ithe hose for drainage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you & thanks for choosing FixYa.
Aug 06, 2011 | Soleus CFM-40 Dehumidifier
How do I switch from continuous drain to draining into the bucket? I have a Danby Pro dehumidifier. Thanks Tyler
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR5009EE Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Doesn't run, turn on or anything............I think it has died. Bought in 2004. Any suggestions? 65 pint/2 speed. Hose connection to drain, no reservoir needed.
the full bucket switch on these models goes bad, o.k.,i know,you said its hooked to a hose to the drain so the bucket never fills up,but,seriously,test the "bucket full" (in the upper right hand area of where the bucket installs) shut-off switch,as this will kill one of these units if it goes bad as it carries all the units power through it at all times,i replace many of these every season,if this switch goes bad it shuts off the entire unit
Apr 16, 2011 | Woods WD25G Dehumidifier
The dehumidifier will not run. It has power to the control panel but the "bucket full" light is flashing RED. We have a hose hooked up to the unit to drain the water and we have check the bucket...
Generally, the buckets on these units can be a little finicky. Especially, if the bucket is not installed properly. In other words, if the bucket doesn't trip the safety switch, when it's out in place and the "bucket full" indicator will remain on and the unit will not run. I suspect the hose attached to the bucket may have gotten the bucket slightly out of place and it's not triggering the safety switch. Turn the unit off, and reinstall the bucket,. Then turn the unit back ON. Make sure there is a little slack in the hose from the unit to the where ever you're draining the water to. In other words, the hose should not be pulling on the bucket.
As I said, they can be a little finicky, so be patient reinstalling the bucket. As it may take several tries, before you get it right.
Hope this helps solve the problem.
Mar 10, 2011 | LG Dehumidifiers
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Dehumidifiers Logo
186 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
