Question about Kodak EASYSHARE M763 Digital Camera
My cam doesnt switch on
I bought a new battery for my kodak m763 coz i thought its just a battery problem. everytime i turn it on the screen just blink for a sec then it shuts off. help me pls....
  • 2,517 Answers
I there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Posted on May 13, 2010
High camera temperature camera will be turned off
We see this happen at my photo store when there is a battery issue. Something like that will more then likely need to be sent off for repair.
Nov 21, 2011 | Kodak EASYSHARE M763 Digital Camera
I have a kodak m763 and it will not turn on or charge what's the problem?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 12, 2011 | Kodak EASYSHARE M763 Digital Camera
My Kodak M763 camera won't turn on, ( It is not the battery because I bought a new one)When I press the on button, It looks like is going to start, but it turns off again.
If the camera has recently been dropped you may have lens damage which is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 04, 2009 | Kodak EASYSHARE M763 Digital Camera
My kodak m763 lens wont open. and when i turn on the camera it says kodak easyshare and it turn back of
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EASYSHARE M763 Digital Camera
I have a Kodak M763. The camara don't want to turn on. Don't work
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Kodak EASYSHARE M763 Digital Camera
Camera wont Turn On
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EASYSHARE M763 Digital Camera
My camera worked perfectly fine until the battery went dead. it wasnt the original battery that came with the camera and i charged it with the charger that did come with the camera so i thought the charger...
your battery area is infected with the chemicakl that is leaked from your old battery.
get it cleaned by an expert with chemical treatment.
also fornat your emory after cleaning
sagar
Jul 29, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak M763 won't turn back on.
Charger specs are critical. Just any old charger won't do.
Jan 30, 2018 | Cameras
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EASYSHARE M763 Digital Camera Logo
308 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
