My computer headset earpiece does not work on my computer.but it does work on my tv socket.A m.p3 headphones plugged into my computer works just fine. this is really baffles me!!!! does anyone know whats happening here....thanks bob
    President:
  • 1,017 Answers
Right click on the Volume icon on your PC and click on Options/Properties, tick microphone.
Posted on Apr 02, 2008
SOURCE:
No sound coming through to headset
need to know more. while headset is plugged in try very gently pulling the jackplug out of the socket, if you get sound with the jackplug positions you may have the wrong six
ze plug or the headset may be faulty. try the headset on other devices that function correctly. Also plug another headset into the socket that the headset is currently is plugged into. If another headset functions then the headset must be faulty. It is a matter of experimentation to find what the problem is but you might need a known working headset to carry out the testing procedure.
Good Luck
May 26, 2015 | AUVIO Stereo Wireless Headphones
Headphone socket won't work
ur connection are wrong i thin
please chek ur owners manual for right ones
May 18, 2008 | Hitachi 37LD6600 37 in. LCD Television
Why does my volume not return to normal levels after using a motorola headset? Is there a way to return the unit to factory settings?
the volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
Nov 12, 2014 | Motorola Talkabout MT352R Two-way Radios,...
Bought new dynex dx-740 earclip headset with microphone. earpiece works but computer not picking up microphone.
Have you installed the software for your headphone? Your computer might not pick up your device because it doesn't recognize the device.
Mar 06, 2011 | Dynex Earclip Headset with Noise-Canceling...
Problem with Motorola S9 Wireless Headset.
Check:
  • Your sound card's Mixer Panel to ensure you have left/right adjusted properly
  • Your sound card may have a speaker-test function, my RealTek tests with "Left" "Right" speech
  • Check your connectors (head phone & speakers) to ensure they are compatible with your sound card
  • Make sure the plug is FULLY inserted in the speaker card socket, it doesn't take much NOT to be fully inserted
dont forget to rate me.......
good luck......
Apr 15, 2010 | Motorola Mobility S9 Headphones
I just installed a Logitech Quickcam. It came with a headset that has 2 plugs, one for mic, one for earpiece but my speakers only have one outlet for headphones. How do I get the mic to work??
On the back of the computer or front there is a GREEN Jack for the earphones and a PINK Jack for the Mike. If you have the speakers plugged into the GREEN jack you will have to pull it out and incert the headphone jack into the GREEN color jack and it should work.
Hope this is of some help. Bud
Jan 12, 2010 | Logitech QuickCam Chat Personal Web Camera
If I jiggle the cord in the stereo outliet, the sound switches from left to right earpiece and has to be just right in the outlet to get both earpieces working at the same time.
If you plug the headphones into another device do they stay on solid?
The problem can be the cord/plug (headphones) or the socket which your plugging into. Socket might need re-soldered or replaced.
Jul 26, 2009 | Bose QuietComfort 3 Acoustic Noise...
My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
May 31, 2009 | Genius HS-04SU Headset
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
Acer Aspire 5102WLMI speakers
Make sure you have the correct headphones for your computer stereo not mono the inner connector on the computer socket and the headset connector must align exactly if the speakrs still play while the headset is plugged in you have the wrong type of headphones connected try logitech brand Headphones designed for computer listening
do you not have plug specifically designed for a headset on your computer?
Jan 13, 2008 | Acer Aspire 5102WLMi Notebook
Computers & Internet Logo
Ekse
Marvin
Marvin
